I want to go lower
Alex33
Go Lower!! I'd guess NorcalSS has something that would work for you.
lx4life
Again man it doesn't look dropped at all in the front, what spindles did u use? I would drop the front with the drop struts or find out if u even have drop spindles. Your truck is the first I have seen that high. after drop spindles, it looks stock. The rear looks lowered though.
J
Jimmyp19
NH
Ground Force Spindles...but I also added Arnott Shocks, I think the spacer on the shock collar should not have been added
derk
Saskatchewan
Let gravity take over and lower it some more. Talk to Tony (NorcalSS) He is super helpful.
lx4life
Yeah take that collar out and see from there. Cause I have seen the ground force kit and it sits lower than that.
alxs210
Reno, NV
You could get some 2500 keys and combined with the spindles you'll go looow.
Boze5
Frisco, TX
Where did you get your grill, I have a crome Billet grill that I spray painted but I want to price a all black mesh grill........
thx
NORCAL SS
SUV SUSPENSION GURU
ok if you have 2 inch drop spinldes I would get the adjustable belltech drop struts.
in rear you would do the tb springs/djm hardware kit/belltech shocks/new bumpstops
$715 shipped to your door.
J
Jimmyp19
NH
for the rear tony, what would that give me for a drop?
I am assuming at full squish, the front would be 4
J
Jimmyp19
NH
tony, thanks for the help, is there a link to what I need on your page?
I know what the front shock will look like and what is needed to install them, but what about the back....also with all mentioned above installed, I have two questions
one: Autoride in the rear will this be affected? Do I need to just rip it out
Two: 4x4, i still need this seeing i live in NH...problems?
thanks
NORCAL SS
SUV SUSPENSION GURU
oh if you have autoride and you want to go lower then in rear do this
http://www.tbssowners.com/store/index.php?act=viewProd&productId=87
and in front you can take that spacer out of your current arnott shocks.
now in front if you want to get rid of the autorid here you go
Here is dylans truck with the 3/5 kit i sold him and the wheels I sold him.
---------- Post added at 08:37 AM ---------- Previous post was at 08:35 AM ----------
btw i can see how the spindles pushed out your front tires they are sticking out the wells. Just be careful if you go lower that it doenst hit the front fenders and warp them.
J
Jimmyp19
NH
awesome.....I feel like you were going to put a link in there and forgot....
J
Jimmyp19
NH
if i do that kit, I need to remove the drop spindles in the front and replace them with the stock ones right?
and do the arms have greasable joints? or do they need to be replaced when they go bad?
NORCAL SS
SUV SUSPENSION GURU
forgotyou had spindles
so you would need
and forgot to add the front camber bushing kit for alignment
$785 shipped to your door.
This will get rid of the autoride set up.
J
Jimmyp19
NH
It doesnt bother me to remove the spindles if the other kit is the way to go (I need to replace my lowers anyways they are shot and I am looking for a Tahoe for my wife, so I could use the drop spindles on the vehicle)...
Thoughts? I know I am monopolizing your time and for that I apologize.
jimmy
TejasPitt
