2dr Sub box.
992door
Greenville, NC
Ok I know it has been done but I cannot find it. Someone put the sub in the area between the rear passenger fenderwell and the back of it. On the right in this pic. Anyone know what I am talking about. I want to put a sub in the tahoe but dont want to have to put a box in the back since there is already not that much room
BigDaddy13440
Rome, NY
99 - I removed the inner fenderwell from floor level up to about 2" below the window, and used 3/4" MDF to make a box to fit in that space. I only fabbed up the front, sides, top and bottom, the outer fender skin is the back wall. Mutiple layers of fiberglass strengthen everything, and I netted about 2.5 cu ft, without intruding into the cargo area.
I actually did both sides, have Celestion 15" subs in each, and still have 49" from side to side. I carry a lot of sheetrock and plywood working as a contractor, I couldn't afford to give up any space.
norcalpilot
sacramento CA
I'm deff interested as well...
best option I've seen is the JL audio stealthbox center console 10" but it runs steep at 650$
I'm not sure if you guys remember that sick 1999 2 door that is on auto trader right now for 17,900$ ?... It's a bad ass rig but very expensive...anyway... that dude has a nice sub in the back that kind of conforms to the rear left wheel well
Some one needs to fab those up and sell them. I would for sure buy one.
I'll post link if I can find it
---------- Post added at 05:08 PM ---------- Previous post was at 05:06 PM ----------
http://www.autotrader.com/fyc/vdp.j...=b&num_records=25&cardist=1424&standard=false
Check out the rear sub pics
norcalpilot
sacramento CA
hey be nice! :flipthebird: :D
I know, I didn't like them either until I put them on my rig. They just worked. My Moto Metal 951s were to flashy for the blackness
ChiTahoe
I've posted this up, it would fit in the right rear wheel well.
992door
992door
Greenville, NC
How big does it need to be for a 12" sub. I figured that one up and it came out to about 2.4 cubic feet. that is without taking into account for the wood thickness
992door
992door
Greenville, NC
Dont know if you have actually looked at that drawing hard but it will not work with anything bigger than an 8
992door
992door
Greenville, NC
Ok I redid my numbers. I came up with 0.62 cubic ft if you use 5/8. That is hardly big enough for anything
992door
992door
Greenville, NC
Well the one that I am getting needs. .5 but it takes up .14 so really it need to be .64 dont know if that little bit is going to make a difference
Oh and i am getting a sundown SD2-10
---------- Post added at 01:39 AM ---------- Previous post was at 01:26 AM ----------
ok wrong again. forgot to take out one thing came up with .56
CKendrick
