Need help no audio in 02 yukon xl
yukondenali
Kansas
Ok so I install my dd in my 02 xl and plugged the aftermarket harness I picked up from walmart. Now the dd turns on but no sound. I checked all the wires and they seem fine. The harness I bought only has one plug and the factory radio has two plugs, is that second plug for the speakers? Because I plugged the factory radio back in and every thing worked so I went and unplugged that second plug (the smaller one) and the speaker didn't work. Did I get the wrong radio harness?
ScottyBoy
Shreveport, La
hook the blue /white amp turn on lead from your deck to the pink on 2nd harness.
THIS. You most likely have the premium sound (not Bose, but a step under that) which has a factory amp and subwoofer. Connect the remote wire to the pink wire in the 2nd harness and you should be good to go.
yukondenali
yukondenali
Kansas
Thanks guys it works now. I guess I do have a premium factory system.
ahumps32
hey guys i connected the blue remote antenna wire to the pink wire from my second harness and still no sound. any suggestions
Jumpshot12
