Finally did my reverse camera
pjtoy2
Banned
Chicago
I'm actually putting a camera where my rear wiper is. I plan on powering it off a switch and the reverse lights. I should be able to wire it to where it will come on automatically when in reverse and still use the switch to be able to turn it on any other gear, in case I'm pulling something or for whatever reason want to look back
jmyler
atlanta
Damn you for putting that thought in my head haha. I want that too!
pjtoy2
Banned
Chicago
All you need is a diode from the reverse wire to the switch wire, that way ur reverse lights won't go on when u flip the switch... or u can do it by switch only and manually flip the switch when u put it in reverse
pjtoy2
Banned
Chicago
How is the monitor held down? I wanna do it but nothing seems like it would hold the monitoe
JoeOmerta
Buffalo, NY
I just did this to my 04 yukon xl. a 20' cable from radio shack is the perfect length. I routed the vid cable along the bumper to the drivers side. up the taillight and vent cap, down along the side storage, up to the headliner before the doors, down the a-pillar and across the dash. perfect length.
The power for the camera is wired to the drivers reverse light. the power for the display is wired to the grey wire on the BCM so it doesn't turn on with the perimeter lighting. I mounted the display using some erector set parts and double sided tape for now. i just need to tweak the mounting point a bit and heat shrink the connections outside the vehicle. all in all it was a pretty simple install.
Also, i didn't splice the wires near the reverse bulb, i pulled the wires out of the socket, and slid the camera power wires through the rubber grommet and re-crimped it all together for a water tight seal.
jmyler
atlanta
My screen should be here soon.. i was wondering where you guys were powering yours. Can you elaborate more? Where is the grey wire in the BCM? I'd like to hook mine up the same way.
Alex33
I've noticed you guys are tapping your camera and monitor power sources separately. What is the reason for that and why can't you tap the same power source for both?
pjtoy2
Banned
Chicago
There's a couple different reasons why somebody would do this. Personally my screen has more than one input so I dont only want it to come on with the camera.
Others might not want to have to run another wire all the way to the back (yes, i know the video cable needs to be ran still so it wouldn't really be extra work) - Also if ur running a cable from the front to back or vice versa there's more of a chance for it to be pinched somewhere or anything to happen
2005yukonxl
missed this thread...thats the same exact setup i used on ours. only thing is i notched that bumper pad out so the camera fits back in a little farther just so the wife didnt bang it with strollers etc.....
and for the diagram on the screen, its on the monitor. not the camera. turn the camera upsdide down or sideways and the diagram stays still. i was going to use one of the monitors at my frt door of my house on the AC power supply it came with in order to check the video feed from the security camera mounted there but didnt want the diagram on it so i didnt get one.
I did two trucks this way, my dad's silverado and this one. the silverado uses a round camera mounted in a round hole and talk about noticing if its off just a bit, since the diagram is in the monitor, if u get it crooked the lines really show u how crooked haha
---------- Post added at 02:29 PM ---------- Previous post was at 02:27 PM ----------
did u use a relay or something in order to prevent it from coming on when u unlock and the perimeter lighting comes on? i tied our monitor into the a pillar wire and just used that as a trigger wire for a ign switched relay so our monitor doesnt come on when u unlock.
wowthatnice
Thanks for all the links and info! I got my monitor within 3 days of shipping and here it is:
Closer look:
Here is my camera:
Closer look:
Look from the site when liftgate open:
Here is the day view:
Night view (and it was raining too):
Sorry for the poor phone camera picture.
BillBlatt18
BillBlatt18
Latham, NY
link for that camera? looks way nicer than mine and i am regreting not getting the wider lens cam
wowthatnice
I bought the same one that you have (same camera same guy in eBay), installed it and day time was great but at night, it's flickering with green screen like someone turn it on and off. Contacted the seller, he send me difference one difference kind and still same issue to I trash them all. Don't want to waste more time on China Made so I spend on this one was great review on Amazon but found it cheaper on Best Buy (local pickup available), got it for $129. This is not wide, it's only 138 degrees horizontal and 92 degrees vertical, but I like it since it use CCD instead of CMOS.
Here is the link
BillBlatt18
BillBlatt18
Latham, NY
thanks for the info. That llooks about what my viewing angle is but i have decided i want more. Will post info when I upgrade
wowthatnice
I think it depend on where you put the camera at. I had tried with 170 degree camera on the same spot and the view wasn't that great. But if I move them down to the trailer hitch its better, the angle is a bit bench because it's too wide and some time it hard to know the accurate of the distance. So right now I have two installed; one for backup and other (170 degree at the hitch) for viewing while driving, my kid love it because she get to see what behind now :)
The images quality is not that great compare to Sony XA-R800C and not sure about the waterproof since I placed it inside the hitch but I’m sure it’s won’t last long with a few car watches. The build quality if very good, it’s all metal with no LED so it’s look cleaner, not fog like my first two eBay cameras.
Here is the link: http://www.ebay.com/itm/270793132134
Tom Joad
French V8 lover.
Chamonix-Mont Blanc ski resort,. France
Unfortunately, access to this particular item has been blocked due to legal restrictions in some countries. We are blocking your viewing in an effort to prevent restricted items from being displayed. Regrettably, in some cases, we may prevent users from accessing items that are not within the scope of said restrictions because of limitations of existing technology. Please accept our apologies for any inconvenience this may cause, and we hope you may find other items of interest on eBay.
WTF ! It's a camera! Not a piece of the Roswell Saucer! :emotions122:
D Rollins
