quote for A/C repair Good/Bad
Bigntall1
Meridian, Ms
I have the infamous noise under my hood from either my compressor or Belt tensioner so I took it to the shop for inspection. I was told that the compressor and the belt tensioner bearings were bad and they gave me a quote for the repairs. Now this shop is Firestone who I know are probably a little more expensive than other non dealer repair shops but I wonder if they are doing more work than needs to be done. Here's the break right off the Recommended Services printout.
Compressor & clutch $457
Drier Accumulator $122.27
Orifice Tube $2.84
Poly rib belt $26.99
Tensioner $62.99
A/C evacuate and recharge $117.99
Labor $251.10
Total after taxes and shop supplies $1143.33
chauncey0337
MLT, WA
I don't know much about AC systems/prices but it couldn't hurt to get a second opinion.
Kman
Southern California
Quote seems about right. I've always been told to replace the AC system on the GMT800's when they fail is around $1000 to $1500.
alxs210
Reno, NV
deja vu man, same exact thing happened to me and got quoted 1300 to do all those things. weird.
B
Bigntall1
Meridian, Ms
Yep you guys are right. I got a second opinion and it was $100 cheaper. The second quote was $1048. He did the quote by phone. However he did tell me that he wanted to inspect it himself because he said that the tensioner don't always have to be replaced.
03z71nj
If u were in jersey we'll do it over a six pack good luck
ScottyBoy
Shreveport, La
I just went thru this a month or two ago. Cheapest quote I got was 1100. I ended up just doing it myself, its actually not that hard. Also, every quote I got they wanted to use a reman compressor or a cheap 4 seasons brand compressor. I ordered a genuine AC-Delco compressor from Rockauto.com for just under 300 bucks. A Delco tensioner is only about 30 bucks from Rockauto. And for the belt, I would replace both belts with Goodyear Gatorback belts.
D Rollins
