speaking of efans....
99Yuk
Northern Ontario, Canada
Do not ignore the importance of the shroud.
I can actually feel the breeze outside the grill of the air rushing in.
Ok, point made.
For the record, I can NOT feel the air moving into the grill by standing in front of it. :)
And I was wondering if the shroud would do anything or not. Seems it does! :D
Stresst
Ok, point made.
I didn't think so! LOL If I couldnt feel anything (with my 17 fans) there is no way you could have! LMAO
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Install one of these in the hood or something.
THE YETI
Director of Operations
South FL
I have an OEM 34" radiator if anyone is looking. $110 shipped.
95TwinTT
Minnesota
Holy shit! Nice pic, know I understand what the TT means in your username! Have any quarter mile #'s? What are your 60' times?
Planning on getting to the drag strip, next Wednesday night. I expect to work on the 60' times with the new 4500 rpm TC, using 4 wheel drive. Should be interesting. :)
AtomicHoe094
Atomichoe094
cleveland, OH
haha Del, looks sick!
Also, is it normal to feel warm air right outside the grille when the fans are on? i think one of mine is wired wrong. Ive always thought that from the beginning but these things still keep the temps down.. idk weird..
95TwinTT
Minnesota
I can’t feel any warm air in front of the grill, only feel a breeze going in, nothing coming out. You should revisit that wiring.
I didn’t use any of Flex-a-lite’s wiring or controls. I did check polarity before hooking them to the relays to be sure they were pulling. I have a separate 40 amp relay on each fan. I plan on hooking up a “hi / low” switch at some point for one or two fans. I want a switch that selects, left, right or both. That way for the spring and fall, I can just run one fan and wear them evenly by switching the duties every other day, from left to right.
The Orange monster is looking good…………. :)
SunlitComet
OBS Jedi-Do Good
You are probably feeling radiant heat or the wind blowing some surface heat back at you.
---------- Post added at 09:22 PM ---------- Previous post was at 09:19 PM ----------
Lets call it the pumpkin.
AtomicHoe094
Atomichoe094
cleveland, OH
haha. what did i get myself into! Ill look back into it del. they both spin the same and you can feel the air go through the engne bay.. :think:
95TwinTT
Minnesota
Fans start at 60% speed with controller
I just realized that I am feeling more air movement on my flex-a-lite fans, than some of you guys, because they come on at 100%. I was reading the instruction page again from Flex-a-lite. Bottom of page 2 “The variable speed control has new features”.
If you use the Flex-a-lite control. It always starts the fans at 60% and will not go to 100% unless the temp rises another 10 degrees over starting temp.
I am not using their controller. My fans are wired right to a couple of relays and they get the full 12 volts when they go on. :)
AtomicHoe094
Atomichoe094
cleveland, OH
Thats probably why you said there pretty loud too. Mine you cant hear running with the truck running, if the trucks off and they stay on for a minute then yea you can hear em. Crazy. Del, when you hook stuff up to 12v, where do you go in the engine bay to get your source? It says directly to the battery, but when a ton of stuff goes straight to the battery terminals, it gets pretty messy..
SunlitComet
OBS Jedi-Do Good
Just use one of the aux power taps with the **** fuse on the under hood block. For the flexalite setup it is a great power supply solution or branch of the battery to some barrier strips for power taps.
ezdaar
Chat Troll
Redneck central, Aka Houston
Mine are so damn loud, when engine up to temp and AC is on, that ppl operating drive through radios ask me to turn them off while placing a order.
dizhai
