Progress on my 96 2dr!
vtx1800sba
Michigan
Well everybody I've had my new 1996 2 door over the last three weeks. If you call recall, my tahoe had just 43k miles and change. It has sat most of its 15 years. So some things needed to be replaced. To date here's what I've done:
1. Replaced all u joints
2. Balanced rear driveshaft after it was determined it had a slight twist
3. New serpentine belt.
4. New tires (Goodyear Silent Armors)
5. Pioneer DEH-47Ph stereo with component speakers in front doors. Rear roof speakers, XM brain and cd player replacement pocket going in this week.
6. Seafoamed the engine. No smoke and I was freakin disappointed!
7. Weathertech floor mats and cargo liner on the way.
8. Washed the tahoe three times so far!
9. Got the torsion bars cranked up to level it out. Old lady that owned it had them backed way off.
Here's what's to come as budget allows:
1. Flush and fill cooling system before autumn
2. Flush fluid and new filter for auto trans
3. Driver side axle seal
4. Change out all other fluids
5. KN CAI
6. Might have an exhaust leak near muffler so might put install Gibson dual in/dual out cat back system. Could get crazy and do a set of short headers with magnaflo cat forward system. Bit spendy though.
7. Figure out a way to get a little more seat of the pants punch to the 5.7. Maybe a bit more mpg.
What am I forgetting?:hands:
moviewithnotitle
Jersey
At minimum I would suggest the following;
(depending on cash flow of course)
CAI (Cold Air Intake) to get some more/better o2 into the motor.
BlackBear Tune. Will give a little more oomph like you are looking for.
Both of these upgrade are inexpensive and reliable.
good luck and keep us posted on the progress.
dsltrc
Virginia Beach, VA
Sounds like your headed in the right direction... But I was warned NOT to flush the tranny.... Just drain fluid, replace filter and fill with good quality ATF... I just did mine and used 6 quarts of AMSOIL ATF...
AtomicHoe094
Atomichoe094
cleveland, OH
he'll be fine changing the filter. Its only the higher mileage trans that you need to worry about. Also dont use synthetic trans fluid..
Other then that looks like your be in the right directions.. ball joints gone at 43kmiles? my truck has 90,000 miles and the factorys are tight.. Hmm.
Youll need 2quarts of diff oil when you change that seal btw
V
vtx1800sba
Michigan
Thanks for the tips, guys! I appreciate it all! BTW ball joints just fine. Anybody ever put in a pair of shorty headers?
BattelWagun
Chi-Town USA
Shorty's aren't that bad to install because of their size, long tubes are the ones that cause problems.
AtomicHoe094
Atomichoe094
cleveland, OH
****** LTs fit in mine just fine. sound great and were only 300bucks ceramic coated.. lts or go home IMO :)
and yea synthetics kill the tranny real quick
96ProCompTahoe
IN
shorties went on fine on mine as well, should drop the extra dime on the LT's.
IRQVET
2 Door Owners Club
Tallahassee, FL.
I never heard that one. When I first got my Tahoe I did several things:
New Gatorback Belt
New Pulley's
New Engine Oil (Mobile One Full Synthetic 10w30)
Tranny Flushed
New Plugs/wires/rotor
K&N Filter installed (Filter only, not the intake system)
I'm sure I did more but I can't remember, lol.
V
vtx1800sba
Michigan
Just got the xm receiver installed. plugged into my pioneer stereo head. My weathertech floormats arrived today. I ordered a set of Husky mudflaps to. Should be here tomorrow.
V
vtx1800sba
Michigan
Mud flaps made it. The fronts should be a snap, but the rears will need to be trimmed as they bump the back of the wheel well. Bit disappointed with Husky on that. You'd think they'd have a cut out so there'd be no drama. The weathertech front floor mats didn't fit for shit. What a ******* pain. Now gotta send em back and swap for something else. I should have stuck with niftys.
blizz
San Antonio, TX
Pics? U joints bad at 43k? I just replaced mine (daily driver for the last 11 years and 45k miles, 83k total) and only one of them really needed replacing but I did em both since I had the DS out.
V
vtx1800sba
Michigan
Back u joint at the rear pinion squeaky squeak. Pulled it off. All four cups dry with powdered needle bearings. Decided to replace all u joints given they are 15 years old and the truck hadn't been ran much in many years. Glad I did.
V
vtx1800sba
Michigan
WeatherTech mats didn't fit worth a shit. The cargo liner did. Sent the floor mats back and got the Nifty Catch-alls coming. Husky mudflaps on now. Got the oil changed, new pcv valve and checked the air cleaner. Like new. Doggone mice built a nest inside the air box at sometime during the Hoe's storage life. Got that all cleaned out. Had the shop run some cleaner through the vacum lines similar to Seafoam. Wiped out the tbe top to. No more sticky throttle. Now just need to figure out how to get the wipers working again.
D Rollins
