ballsie
Will the tpms sensors from a 2010 Tahoe work on my 04?
Not sure if 04 had tpms? But in any event, no. 08+ used a different sensor then 06-07.
Aftermarket replacement $27 from amazon
Orange Part Number: SC2575
Replaces the following manufacturing part numbers:
OE Supplier: Schrader
OE Sensor Part Number:
15136883
Schrader Part Number: 20115
Dill Part Number: 9115
Relearn Procedure:
1. Apply parking brake. Turn ignition to ON position (engine off)
2. Turn headlight switch from OFF to parking lamps 4 times within 4 seconds. A double horn chirp will sound and the TPMS telltale will begin blinking to indicate the learn mode is enabled.
3. Starting at the LF tire increase/decrease pressure until horn sounds.
4. After horn sounds, proceed as in step 3 for the next 3 sensors in the following order : RF, RR LR.
5. After LR sensor has been learned, turn ignition to OFF position. Adjust all tires to pressure listed on tire placard.
*If headlight switch does not enable TPMS Learn Mode, use TPMS Learn button on dash.
OE Replacement Installation Videos
OPSS 2 Manual
OPSS 2 Video
Download the application guide to manually search for sensor part numbers.
Replacement sensor for the following vehicles:
Cadillac Escalade-ESV-EXT 2004
Chevrolet Avalanche 2004
Chevrolet Silverado 2004
Chevrolet Suburban 2004
Chevrolet Tahoe 2004
GMC Sierra (all) 2004
GMC Yukon (all) 2004
