TPMS compatibility question
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Aftermarket replacement $27 from amazon
Orange Part Number: SC2575
Replaces the following manufacturing part numbers:
OE Supplier: Schrader
OE Sensor Part Number:
15136883
Schrader Part Number: 20115
Dill Part Number: 9115
Relearn Procedure:
1. Apply parking brake. Turn ignition to ON position (engine off)
2. Turn headlight switch from OFF to parking lamps 4 times within 4 seconds. A double horn chirp will sound and the TPMS telltale will begin blinking to indicate the learn mode is enabled.
3. Starting at the LF tire increase/decrease pressure until horn sounds.
4. After horn sounds, proceed as in step 3 for the next 3 sensors in the following order : RF, RR LR.
5. After LR sensor has been learned, turn ignition to OFF position. Adjust all tires to pressure listed on tire placard.
*If headlight switch does not enable TPMS Learn Mode, use TPMS Learn button on dash.
OE Replacement Installation Videos
OPSS 2 Manual
OPSS 2 Video
Download the application guide to manually search for sensor part numbers.
Replacement sensor for the following vehicles:
Cadillac Escalade-ESV-EXT 2004
Chevrolet Avalanche 2004
Chevrolet Silverado 2004
Chevrolet Suburban 2004
Chevrolet Tahoe 2004
GMC Sierra (all) 2004
GMC Yukon (all) 2004
frankf72malibu
Richardson, TX
Not sure if 04 had tpms? But in any event, no. 08+ used a different sensor then 06-07.
15136883
Relearn Procedure:
OPSS 2 Manual
OPSS 2 Video
I used SunlitComet's process and it worked perfect on my wife's 07 Tahoe. Thanks SunlitComet!
Yeti,
FYI - I swapped out 2007 stock 17" rims for 2012 20" rims this weekend and the 07 relearned the 12 sensors. Thinking the 07 to 12 sensors are compatible then.
Overall, glad I joined this forum as it answered this issue as well as issues with my 03 by just searching. Thanks to everyone for posting the info.
briannorris
