Tahoe Lack of Power Stumbles on Acceleration when Cold..
stikky_p
Hey guys.. I'm new to the forum and a 4th time Tahoe owner.. Unfortunatly I've never had this issue.. Hopefully you guys can help..
For starters it usually only happens "noticibly" when the vehicle is cold and has been sitting for hours or overnight. I start it, put it in gear, press the gas and it goes but stumbles and seems like a drastic loss in power. It does not rev up in terms of a slipping transmission. After driving a couple blocks it seems to clear up and be driveable.. During normal conditions it also has a lack of power.. I do have an engine light on but i've had it checked numerous times and its the evap sensor.. I'll fix that later..
I had a family friend look at it who happens to be a GM transmission tech at our local dealer and his first thoughts were not transmission but a clogged Cat.. He recomended i purchase a heat temp gun (29.99) and test the back and front of each CAT Converter.. I didn that.. the rear or the CATs were hotter then the front which is normal from what i understand.. A increase in Temp in the front would mean a restricted system causing pressure.. He then thought possibly dounle checking with a Pressure gauge but I haven't got that far..
None the less I'm looking for other alternatives. I don't want to book it into the shop and pay $109hr for someone to tell me something silly.. Im getting no codes and not to familiar with this 2000+ stuff.. Can anyone offer suggestions..?
2005yukonxl
clogged cats usually set some codes based on the o2 sensor readings. have u had the codes checked? most exhaust places can check for cat flow as well...usually for free. u may have a chronic evap code but i bet u have others as well now... check your codes if u have a scanner or run to auto zone and let them do it for free...then come back with that info and we can help....
S
stikky_p
Fortunatly I have a code reader handy.. The codes are
P0446 Evap Emmission system vent control circut
P0453 Evap Emmission system pressure sensor/switch high input
Same codes I had before that refers to the Canister or switch issue.. No new codes were thrown..
2005yukonxl
well crap. that doesnt help any.
you can do this- take out the forward 02 sensor, ahead of the cat, and then cold start it. if its a clogged or partially clogged cat that will create enough of an exhaust leak to see if thats the issue. it will throw a code if you drive it that way of course or if it idles long enough to not get any readings but seems u can reset them since u have a reader. i eliminated a stupidly annoying drivablitly issue that way with a dodge neon i built for my bro in law.
Thumper8302
OKC, OK
clean ur throttle body man.. ive owned my yukon xl for a lil over a year and a half.. 2001 with over 240,000 on the clock... give it a good clean and since u have to take the intake tube off u might as well clean ur mass airflow sensor as well... make sure u get cleaner specifically for the mass air flow sensor.... i had the same issue as u on this and it cleared it up.. havent had an issue with this in over a year
S
stikky_p
Didn't seem like it helped.. Im going to try the throttle body cleaning tonight and give you an update tomorrow.. I'd like to make sure it isn't a transmission issue before i spend the $$ on 22" shoes for her.. here's hoping she gets new shoes:hands:
fire730
Louisiana
I had a similiar problem on my 98 5.7 Vortec.
Mine ended up being a cracked head so it would leak coolant into 2 of the cylinders when it would sit for a while. After a minute of driving and the coolant in the cylinder cleared it ran fine.
Im sure you heads arent cracked since they are aluminum but it could be a head gasket leak. Has the truck ever been overheated or does it use any coolant?
Just throwing out ideas. I would kinda rule out the cats cause you would most likely get a P0420 code for catalyst inefficiency. I really dont think it has anything to do with the tranny.
How many miles on it?
S
stikky_p
It's got 202000kms. I haven't noticed any coolant issues or fluid issues at all.. Although this is one vehicle that I haven't checked the plugs, cap, rotor or fuel filter.
fire730
Louisiana
Well I would definitely start with plugs, wires , and FF. If they haven't been changed recently.
S
stikky_p
You have a good point. I'll start there and I guess if that's not my fix at least I'm confident it's been tuned up. I'll spray the intake too while I'm in there. I've already cleaned the maf but noticed no change. I'll post pics for an update.
Thumper8302
OKC, OK
clean the throttle body first then run a seafoam treatment before u do the plugs.. ull be surprised on what $15 can do for ya
S
stikky_p
I've never used seafoam before.. If i'm correct it should be 1/3 in the gas, 1/3 in the oil fill cap and 1/3 sucked in the brake booster vac line?
I've also seen some people just add it to the gas tank instead..
Is the seafoam ok for the engine. I assume since they make the product but i've never been a additive kinda guy.. Usually if you need an additive its covering up another problem and not fixing one..
S
stikky_p
So I used the sea foam spray that goes directly into the intake while revving. I followed the exact steps but not a whole lot of white smoke came out. Maybe a couple large puffs but nothing crazy.
I also cleaned the throttle body and butterfly/plate before hand.
I haven't noticed any gained power or anything to suggest it's fixed. I'll wait till morning and test it cold.
waxworkz
i did half a can sucked up into booster, half into oil. did see a lot of smoke for a bit. at first it looked like my truck was burning, then trailed off. a lot smoother idle, better response on acceleration.
S
stikky_p
I went to purchase the regular sea foam but they were out. So i bought the spray. From what i read they say the spray breaks up easier but for some reason i think the 1/3 in each would make a better solution. Who knows though..
Before i do plugs and wires i was told to do a Exhaust Pressure Test in front of the Catalytic Converters.. I borrowed a test gauge and i'll do that first.. I'll keep you updated..
S
stikky_p
Here is the video of my pressure test.. I was told to hold it at 2500rpm and see if it goes about the green.. It doesn't.. However when i rev it to 4000rpm the gauge spkies large.. Is this normal?
http://www.youtube.com/watch?v=r07Mgfommls
I also attached pictures of the spark plugs and wire that i pulled.. Seems to be ok.. However i did notice that the plugs are NGK TR55GP.. I've never used NGK for anything but a import before... Is This Normal? I however didnt pull all the plugs.. Just 2 that looked identical..
I am still currently having the issue of the hesitation and lack of power.. I notice it more on cold startups in the morning.. When i push the pedal it feels like it bogs down then goes after about a block..
S
stikky_p
Problem seems to be getting worse.. If it dies at least i know whats wrong.. Still no other engine code besides the emmission pump
S
stikky_p
Ok so upon further digging i cross checked the TR55GP NGK plugs and from what i've found either they have upgraded to a different plug or dont list that specific plug for this vehicle. As well under more review the plug doesn't have a good turnout.. Seems that after 1000miles the plugs act up and misfire.. I purchased GM AC Delco factory replacments and a factory fuel filter.. Cross my fingers it gets fixed...
Freedom Motorsports
What type of scanner are you using? There are some codes that won't throw a CEL and there are a lot of scanners out there that won't read all the hidden "Dealer only" codes.
Just thinking there may be more codes in there, maybe. Honestly, I would also replace the Evap, there is an upgrade from GM on those that moves it from back at the tank to up by the transmission, not sure why they did they exactly but I changed one on a customer truck about 3 months ago and his was doing similar things. Of course at the same time he was also getting O2 sensor codes so maybe on his it was the combination of the two.
S
stikky_p
anyone know the proper way to clean the emmision cannister on the rear? I'm getting a check engine light and was told to just clean it out real well because of dust.. Apparently its common to clog and not allow the switch to work.. Anyone got advice or a writeup perhaps?
Hodmjstone
