Just ordered BlueFusion
Green Machine
Orange County, CA
Finally done with the BlueFusion install. It only takes a few minutes to get it up and running but I spent quite a while tucking it all away.
I had to pop off the side cover of the dash, remove the grip handle, remove the A pillar, pop out the visor and clip, and then pop off part of the headliner to run the mic underneath it all.
Made one call while driving and the person I called appeared to be able to understand what I was saying. I haven't checked out the audio quality on the other end so that will be another test for me.
So far it has been worth the $89.95 I spent for it!
Green Machine
Orange County, CA
Update: BlueFusion works pretty well. Just takes some memorizing of the controls. The kit comes with a cheat sheet that is helpful. Audio quality is fine in the truck. It is a little jumbled on the other end but for me the caller's voice is easy to understand. Basically sounds like Voice Over IP setups (think Vonage and Ooma). I've also uploaded pic of where I stuck the BlueFusion box with some 3M double-sided adhesive. When I first stuck it to the XM tuner like in the video, I could not close the glove compartment. I now have it stuck to the frame to the right side of the glove compartment.
Jades Dark heart
Jades Dark heart
Allen, TX
I too stuck it to the XM module first just like the video. Couldnt close my glove box either. I put mine pretty much in the same place as you :)
Greg
plush
So did I read somewhere that this does not work with Gen6 LockPick? Both seem to be $239, any place cheaper and which one would you get first?
Green Machine
Orange County, CA
Not sure about the Gen6. I have the GMX550 and BlueFusion and was having some problems. The stereo would frequently not turn on. I then emailed Scosche and got the following email:
"The Scoshe BlueFusion is not compatible with the GMX550. We recommend Parrot universal handsfree bluetooth device. Thanks and have a nice day!"
After removing BlueFusion I didn't have any stereo issues for about a week...until yesterday. Even without BlueFusion installed, the stereo wouldn't turn on. I was able to turn it on by pressing the Disc Eject button. So the stereo issue doesn't appear to be caused by BlueFusion but in my case did seem to be aggravated by it (I'd get the problem in about 1 in 4 tries). If hitting the Eject button turns out to be a solution, then I'll probably still live with my glitchy GMX550/BlueFusion combo.
Hope that helps.
UPDATE 7/15/11:
With the GMX550 and BlueFusion back in, the radio again wouldn't turn on this morning. For the second time now, hitting the Disc Eject button turned the radio on. So if others come across this glitch, try that button. I'll continue to test this out.
04ctd
Charleston SC
what is Lock Pick?
forgive the stupid question...but why do you blue tooth your phone calls?
clarity?
hands free required in your area?
just to be cool?
i have a nice Navi Unit in the other truck, and a BT module is cheap, but i never could figure out why i would want to talk over the radio.
FWIW, i HATE talking on the phone, would rather text. a big part of that is having hearing loss (10% per military)
wife talks alot, but i don't really want to hear her talking about shopping
just kinda wondering out loud, am i missing out on something?
we had a "CAR PHONE" when they first came out, and they had speakerphone, was pretty cool in the early 90's.... :party33:
Green Machine
Orange County, CA
Lockpick is a device that allows one to watch a movie on the head unit screen while the vehicle is moving and allows one to enter a destination into the NAV system while the vehicle is moving. There is also an Ipod option so that music and video can be played through the OEM system.
http://coastaletech.com/gen6lockpick.htm
Adding bluetooth is for hands free cell phone operation. In my state (CA), a driver can only use a cell phone through a hands free setup.
Jades Dark heart
Jades Dark heart
Allen, TX
Still very happy with my BF module. I have had it in my truck for a month now and people I talk to on the phone say they can hear me way better than they could on my Pioneer 8000BT that i had in my 04 Hoe, may she rest in peace.
ChevyFreak
New York
do you also have a gen 6 lockpick or gmx550 installed?
Green Machine,
I purchased Bluefusion from that eBay seller that you mentioned in an earlier post. Thanks for letting me know about that as I saved a bunch of money! I already had the GMX550 installed.
I just wanted to let you know that I have been using the GMX550 and Bluefusion for several weeks now without incident. I am not sure what is going on with your radio, but I think it is something more then just the lock pick and the Bluefusion combination.
Green Machine
Orange County, CA
ChevyFreak,
Thanks for the info. That helps a lot with my troubleshooting. It let's me know not to give up on BlueFusion just yet. Was getting ready to go with a Parrot system but I'm going to hold off for a little while longer.
chris_26
Just installed BlueFusion in my 08 Tahoe. The installation took 15 mins, and contrary to other reports, the unit fits behind the glove box JUST FINE. Works great on initial tests, I'll post again after I've used it for a month or so.
plush
I think you got your reports confused. the only fit issue I have seen is getting the lockpick install behind the glovebox. At least in this thread everyone put in right where you put it.
Green Machine
Orange County, CA
I think the issue was that if you stick the BF box to the XM tuner like in Scosche's video, the glovebox cannot be closed. At least that was the case for me and someone else.
chris_26
The confusion might be on your end. Like I said in my post, I installed behind the glove box. "Jades Dark Heart" and "Green Machine" both had issues with fit, which is why I commented on it.
Green Machine
Orange County, CA
chris_26,
Do you have an XM tuner box behind your glovebox? Regardless, I'm glad everything fit. I'm amazed you got it all done in 15 minutes. Even if I knew all of the steps ahead of time, I don't think I could get it done that quickly.
I also thought maybe the fitment issue could be Hybrid specific (my truck) but it looks like Jades Dark Heart has a non-hybrid. So I'll throw that theory out the window.
Jades Dark heart
Jades Dark heart
Allen, TX
chris_26,
Yeah I have an SLT and if you mount it to the XM module, you will NOT be able to close the glovebox. Its not a big deal to move it as you have seen, just really odd that the video shows it like that.
Either way its a great product. I use mine almost every second I am in my Yuk listening to music on my phone.
Greg
jarthead
St. Louis
Anybody running this with a non-nav system? I am wondering how the interface will work with an 07 SLT without nav. Would appreciate any feedback!
worleytrev93
