Time For New Speakers!
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
I have been trying to NOT to make a thread on this but i''m absolutely lost....
i'm looking to replace all my speakers in my hoe I enjoy all kinds of music but mainly rap so i want a setup that sounds crisp and bumps too....i dont really have a price range but fairly priced items with performance would be nice.
also ill probably get an amp...what else will i need??
please help me....LOSTTT!!
Sir-Lancelot
South Carolina
Really need a budget Bro, I can spend the hell out of other peoples money. lol
Are you looking to just replace the door speakers?
Adding subs?
Both?
What is your experience level with installing and fabrication?
Need more info Buddy!
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Adding subs?
Both?
No experience but I'm sure I can manage.. I also have a buddy helping me who's done around 16 cars.. Fabrication wise I can do anything I can draw up freehand or on cad with wood/fiberglass...but I'm looking to just replace the existing speakers I'm not looking to put 6 speakers in each door if you know what I mean... I'm planning on doing subs but I'm not ready for that project yet.
Budget is anywhere from 650-1300 but I rather not break bank I'm not looking to make any world record system just musically pleasing that thumps and is crisp ;)
HAYN_HO
gulfport, ms FROM oahu, hi
if you run a 4ch amp designated for you door speakers..i would go with kicker KS series if you have the money its a few hunred for a set i believe ... but if you dont have the money then settle for the DS line up i had the kicker QS series for over 3 years and never once dissapointed me and i play my music loud as hell
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Mob and qf also chimed in saying addictive audio? And focal someone else mentioned hybrid audio? Only one I have heard of out of those is focal lol...reason why I'm not doing subs yet is because I'd like to replace my stock speakers first....i think doing subs first world be like going ass backwards...I'm looking at fi subs in the near future though!
Sent from my SCH-I500 using Tapatalk
Huck
Whut Thee Huck?!
San Diego
which amp are you running? I'd go with Kickers or Focals.
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
What do I need for the doors ..4 tweeters and 4 Coaxials.?? I haven't heard of addictive audio soo I'm weary on them... How good are kickers speaker wise?!
Huck
Whut Thee Huck?!
San Diego
Comps up front, coax in the rear. Spend the money up front, that's where you sit. Use the rear for fill. 4 Channel amp. Or if you're not going super huge with the sub a 5 channel. Seems like you're going too large to use a 5 channel, though. For your price range you can get some Kicker QS65.2 up front (about 400). And then some Kicker KS65 in the rear. Run them off a 400.4 and you're good to go!
Of course you should go listen to a bunch of different speakers first. I don't know how you like your music.
Sir-Lancelot
South Carolina
Based on your goals and waiting on the subs until later, I would say a nice 8" midbass in the front doors with a ring tweeter in the a pillar or even a nice fullrange on axis in the a pillar.
You would need to run active, but it would be worth it once that midbass shakes your side mirrors. :)
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
I'm looki.g to add 2 12's and a new 8 for the factory spot in addition to the speakers so wouldn't I need more channels? Spending money up front sounds goods to me!
abladeafficionado
Don't replace the factory sub, just add 12s later.
I'm making this list based on the assumption that you're running an aftermarket head unit with a built in (very small) amp. For $1150 I built a system sans head unit and install gear.
Amp, 100W RMS @ 4Ω bridged on, $150
http://www.sonicelectronix.com/item_21951_Kicker-ZX650.4-10ZX650.4.html
Front Comps, $190, bridge amp for these, they're only rated to 85W RMS, but they'll take 100W no problem
http://www.sonicelectronix.com/item_19750_Boston-Acoustics-SR60.html
Rear Coaxs, $65, run off of head unit power so about 15-20W RMS, rear speaker are just for fill, don't spend a bunch of money on rears
http://www.sonicelectronix.com/item_5022_Boston-Acoustics-S65.html
Sub Amp, $350, 1000W RMS @ 2Ω
http://www.sonicelectronix.com/item_21957_Kicker-ZX1000.1-10ZX1000.1.html
Sub, $400, IDMAXs will get loud but are extremely clean sounding
http://www.sonicelectronix.com/item_20482_Image-Dynamics-IDMAX12-V.3-D4.html
That leaves you at $1150. I built this with SQL in mind, loud but still clean, it will get plenty loud but sound clean while doing it. Build a 2.5 ft^3 box ported at 30Hz for the sub, and then spend some money and do a Big 3 upgrade, and use the rest of the budget on wiring. You should come out somewhere around $1300 for all of that if you do the install and box build yourself. I only put ONE twelve in the build, 1000W on a good 12 (like the IDMAX I suggested) will be superior to two cheap 12s on 500W a piece. To increase your SPL 3db, you must double your wattage, or double your cone area. So mathematically, 1 12" on 1000W will be nearly as loud as 2 12", and sound much better while doing it.
I wouldn't recommend Infinity speakers if somebody recommends them, the titanium tweets are harsh. Focals are nice but you have to hear them before you buy them, they have bright sounding tweeters that many people don't like.
HAYN_HO
i had both those amps and they're sweet you wont be dissapointed i heard the speakers in a friends car with a 4ch amp and they do sound good..however i dont know what the sub sounds like but i can only imagine it sounds good .. from the specs sounds like it pushes has a pretty good review also
---------- Post added at 06:56 AM ---------- Previous post was at 06:48 AM ----------
btw spend the money on wires..dont be a cheapo i used the kicker 0/1 gauge wire and they are flexible as hell (well at that thick you think about this when it comes time to hide your wires, etc.) when i was installing car audio they used tsunami wire and there was a big difference in sound quality esp. when you add the RCA's
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Im planning on fiberglassing my own sub box which oughtta be cool...and what are Rcas?... What's the better wire these days?
abladeafficionado
RCAs are your white/red wires that run from the head unit to the amp(s).
Definitely spend money on good wire, you don't have to use the kicker stuff though. If you can get ahold of 1/0 welding cable it works well too, the strands for welding cable are much thinner so they're flexible probably a lot cheaper than the Kicker wire. I get all of my wire from work on giant spools, so I don't know the cost of it for consumers.
Be careful fiberglassing a box. You have to do it well or it'll flex like no other. Building a simple ported box out of wood, then glassing over top wouldn't be a bad idea. Then you're guaranteed the correct box dimensions, and can still have a nice looking fiberglassed box.
If you're looking for more help just ask.
Here is a box plan, 2.5ft^3 @ 32Hz before displacement.
http://imageshack.us/photo/my-images/29/25cubes32hz3125sqin0zp.png/
D Rollins
