Water in door
ltzhoe08
n.y.c.
hey guys.. i have an 08 tahoe and on my way to work today i heard water swishing around when i stopped short..i checked it out and my rear pass door has a decent amount of water in it..enough that when i swing door it sound like a pool...cant seem to see where it is coming in from...anyone have this happen to them before or have any ideas...thanks a lot
bmwme
Just found this on my '07. I opened the right rear door and I heard the sloshing. It was drippin out under the door so I cleared away some crud and it started pouring out for 5-10 mins. There is some rust in the corner too...darn
I will now go check this on my burb but I have not noticed it just yet. Definitely do NOT want rust starting on such a new vehicle!! :banghead:
L
ltzhoe08
n.y.c.
yea same thing with me...it was dripping out the bottom..think i ha a lot of water in there...but my window and speaker are working fine thank god...i just checked the drain holes and they do seem to get clogged...but not the front doors..just the rear ..
---------- Post added at 01:04 PM ---------- Previous post was at 01:03 PM ----------
where did you clear crud from... the drain holes?
GM Customer Service
Michigan
Ltzhoe08,
I am sorry to hear that you are having this issue with your Tahoe. Did you get the water out of your door? Also, is there any sign of rust on your door? Please keep me updated with this issue.
Thank you!
Elizabeth, GM Customer Service
L
ltzhoe08
n.y.c.
yes it dripped out...do you know if a little water is supposed to get in the door gm service?
GM Customer Service
Michigan
Bmwme,
Did you notice just surface rust or is there an actual hole?
Ltzhoe08,
I am not entirely sure if this is common or not. I am going to research this further and I should have an answer soon. Thank you for your patience.
Thank you!
GM Customer Service
Michigan
The door does have drain holes at the bottom. It is not uncommon for water to make it past the outside sealing strip. If there is a lot of water in the door then I would encourage you to check out the drain hole to make it is it not blocked so the excess water can get out.
Thank you!
Elizabeth, GM Customer Assistance
L
ltzhoe08
n.y.c.
Thank you gm rep Elizabeth , your the only rep that has ever helped me instead of telling me to keep them posted on what the outcome is. I appreciate it.
:word: @ ltzhoe!
thirsty1258
I say add some gold fish. How many have that mod
sent from my thunderbolt
GM Customer Service
Michigan
Ltzhoe08,
You’re welcome! I am happy to help. If you find that your door is holding an excess amount of water again check the drain plug. If it is clear and you still are getting a lot of water build up, please let me know!
Thank you!
bmwme
Bmwme,
It is not rotted through, but right under the hole is where the outer door skin wraps around the inner skin so water collects right there and it is rusting...surface for now but rust never goes away so eventually it would rust through.
I am out of my factory warranty but still have a dealer purchases warranty. Would it cover rust like this or am I on my own?
GM Customer Service
Michigan
bmwme,
You would need to speak with the dealership to confirm if the warranty you have through them would cover the surface rust. I would also advise you to speak with your dealership to confirm if there is a faulty part which is making the water stay in your door. Our normal rust warranty only covers if there is an actual hole from rust. If you do speak with the dealership, please let me know if it is covered or if they will cover it themselves.
Thank you
2007gmcyukon
Southern California
This same thing happened to me about a year ago! I thought I was crazy, but there was water in my door, same door too. I just removed the drain plugs and let the water drain out and never had any other problems. It's interesting to know I'm not the only one that had a door full of water.
Greg Taylor
This is the third Yukon I've owned. I bought a used 2013 Yukon Denali and the driver-side passenger door started holding water. I thought the swishing sound was the fuel tank, crazy, it was the door holding water like a fish bowl.
First time that has ever happened to me and only one door. IMO the problem is the drain holes on either end of the door. If you look under the rubber trim at the bottom of the door you will see a small hole. This drains the water that might get into the door (how water gets in there in the first place I don't know).
Ok, the holes on every other door are unobstructed. On the door with the problem, it appears to me that the rivets/welds bleed over slightly and impede the drain holes. They are not obstructed with mud or such, it is the welds that are obstructing. It is a manufacturing defect that probably happens every so often, but enough to create a post.
Really disappointed in this problem. I'll take the car to the dealer and see what they think. If they have a different idea I will post it here.
93blkongreenpro
I had this issue last saturday. I also, thought it was the fuel tank, but thought it was odd. Upon opening the driver back door, then I realized where the water was. I pulled up the black stripping on the bottom, and 6-7 minutes later, it was empty. I thight that was fairly odd until ive read 3- 4 threads on it.
Sent from my SM-N910P using Tapatalk
Buford bubba
