03 hoe, 35s with keys
Jbird
Just put these on yesterday. Have cheap ebay keys and thats it. Toyo m/t 35s with rockstar 20s. Had to do a little trimming nothing major
Arctic-Rodz
RGV Texas
uff... stuffed! thats crazy. I have a 6" on mine and I had to do quite a bit of trimming to clear my 35's
Sickblutahoe
Montrose CO
Its weird to hear people say the had to trim with a six inch with 35s. Now keys with 35s is a different story. You should lift the rear it looks like you've got a load in the rear cause the fronts so much higher.
Arctic-Rodz
RGV Texas
Id depends on the offset of the wheel. Mine stick out about 2" from the fender.
Do your tires rub on the inner fender under suspension flex? i cant imagine it not rubbing at all with 35's.
and yea, that a little too much "cali" lean
brucebruce45
Your lift pushes the wheels out further as well. To the op, take some better pics
zaathur
looks good wish just my 33s wouldn't rub backing up because of my offset
chacho44
MOTORCITY
i just put 33's on stock 20's on mine, Nitto Mud Grapplers. Rear is good front rubs a bit, Might consider the cheap egay lift as well.
polobuds
East Bay, CA
i have 33" nitto trail grapplers on mine. front rubbed a little when in reverse. i trimmed the inner wheel liner and all is good. you try doin that already?
Jbird
Jbird
yea if the wheels stuck out any farther the front would rub to bad. Im getting 1'' coil spring spacers soon
polobuds
East Bay, CA
got 1" spacers in mine.
yours looks badass. Kinda makes me wish I went with 35s instead, but I was worried the rubbing would be worse. f*#^ me. Oh well, 33s will do
thor1125
orange county
Could you post some clearer. Pics of your tahoe... I really like the look and wanna we what yours looks like in a better angle in some light. Thanks bro ...
Sent from my DROIDX using Tapatalk
DuckHunter
Senior Member
Arkansas
Question
DO you remember what keys you bought? The maker of them? How much did you end up payin for them? thanks
Jbird
Jbird
i had a cheap set of ebay keys. they were around 60-70 shipped off ebay. They gave me as much lift as rough country keys
jdpber
GOLD MEMBER
The America
Not a bad look. be careful on any turns that make you articulate so you dont grab that bumper corner..
the off set on those rockstars is probably 18 or 30.. that is the most common off set in the KMC wheels i sell..
moto
