Problems..
MTman777
Escalon, CA
Ok guys.. i just bought this tahoe 2 weeks ago and i have an issue id like to address... it doesnt blow any air up front at all. A small amount comes out when the controls are in the off position but its not much and i can still control the temperature. Its not just the dash vents its everything. Nothing blows up front. However.. the back blows just fine but i cant control the temp. Its just cold in the back. Any ideas what could be causing all this? I just replaced all the hoses under the hood and the thermostat. Im thinking it might be the front blower motor but im not sure. Any clue as to where i should start????
---------- Post added at 02:55 PM ---------- Previous post was at 02:51 PM ----------
SORRY GUYS... posted this in the wrong year.. trying to get used to this forum. My tahoe is a 99 5.7L
MTman777
MTman777
Escalon, CA
hmmm.. ill have to try that too... but the problem isnt with how cold or even how little air is blowing. Its that it doesnt blow at all.. the air just kinda seeps into the cab.
MTman777
MTman777
Escalon, CA
sooo.. checked the fuses today... all good.. so that only leaves faulty wiring or a faulty unit...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Disconnect the front blower connector and test for voltage on the control side of connector for voltage on the purple wire while going thru different speeds. I am assuming all speeds do not function. Correct?
I take it the front or rear controls for temp do not work correct? If so then go after the temp control motor in back.
MTman777
MTman777
Escalon, CA
the temp control motor? I have not a clue.. lol ... and yeah.. no speeds at all. But heres the weird thing. If i turn the hvac controls on then i loose all air. It doesnt seep into the interior anymore. And the air that does seep into the interior.. i still have control over the temp.
SunlitComet
OBS Jedi-Do Good
Let me rephrase that. do both front and rear controls not control rear temp door motor or is it just one off them?
Second can you double check Fuse 12 from the instrument panel and verify one of the fuse terminals has power and at what voltage using a good ground for the negative test lead on a multimeter.
Diller
Cedarburg, WI
If I read this correctly (and yes, I may be retarded), he only has rear a/c. My '99 is the same way.......cold air in back or no air at all. No heating option.
raptorforme93
Tampa, Fl
This may not be it at all, but some people have problems because the back of the HVAC panel is exposed and if you take out the radio and the antena cable touches the exposed circuit board, it will cause a short. This could possibly be related to your problem
Devious_Tahoe96
Mr. Budwieser
West Texas
^^^^Hahahah thats why mine isn't working lol
Dealership said the HVAC isn't getting 12v so i need to replace the entire unit. $344 part. Autozone doesn't have it so...JUNKYARD it is :)
fyremanpat
Fyremanpat
x2 on the heater/fan control. Ive been through a few of them...also it could be the resistor element thing behind the glove box in the actual hvac. If you dop the glove box all the way its right there, you cant miss it (I forget what its called). That part you can get at autozone and places like that. You can find heater/fan control units on ebay for around 100 bucks...On another note any Tahoe with rear air is for A/C only, not heat. Hope this helps.
raptorforme93
Tampa, Fl
Those things are $344?!?!?! mine is messed up for other reasons but still functions. I will also be getting a junkyard one!!
Devious_Tahoe96
Mr. Budwieser
West Texas
Sad to say... but you can find a whole bunch of obs Chevy's in the junkyard, but on a brighter note, they make finding replacement parts easy lol
SunlitComet
OBS Jedi-Do Good
The fan control should not be affected by the circuit board. Its wiring on it own connector according to the diagram although in the off position it dos disable compressor commands. On all speeds except for hight it goes thru fuse #12 on the i/p fuse panel and thru the resistor. On high current from that same fuse triggers a relay direct connects the fan to a 50A fuse under the hood. so if you check for voltage at the fuses and at the blower motor you can find the problem right away.
fyremanpat
Fyremanpat
If the fan isn't blowing at all and the fuses are good I seriosly doubt its anything else other than what I have described... ive had my truck since new and have replaced it three times and it was having the exact same symptoms. Also when you pull the control unit check the plug in the back to make sure you're getting good contact. It caused mine to short out until I bent the prongs out a little. Its very easy to replace.
Off-topic: I just gotta say every time I see this thread when I pull up the 'new posts' Jay-Z's song "99 Problems" pops into my head.... :whymewhyme:
on-topic: back to our regularly scheduled programming....
MTman777
MTman777
Escalon, CA
So.. Where exactly is this board located at?... Also would that cause the rear to only be cold air?.. i thought you could control the rear with the temp in the front... are you sure its only a/c in the rear?
dizhai
