Lowering a Hybrid
THE YETI
Director of Operations
South FL
Omg that looks so clean!!!!
Sorry your ride is bumpy. Maybe Tony can chime in as to why?? Our ride is damn near stock.
As far as the steering, sounds like it needs the alignment and that should solve your "tracking" issues.
For what it's worth, we drove our Burban through DC with no issues dropped on the 24s.
soulsea
Bar
No rubbing issues ScSS?
---------- Post added at 03:47 PM ---------- Previous post was at 03:32 PM ----------
Btw, we discovered that the HyHoes don't have autoride, so maybe that's why the ride is so bad.
I don't know what to do, but if there's no easy fix to the ride and the rub, it'll have to come off no matter how good she looks. :(
THE YETI
South FL
I don't want to speak for Tony about the ride, but if you didn't replace the shocks, that could be your problem.
As far as rubbing goes, we might have different offsets. We have zero rubbing at any point with 295/35/24 tires. We did with 305/35/24 tho, but it was minor.
Hang in there, we'll get you situated. :)
soulsea
Bar
I have a 20mm offset and the tires are 295/35/24.
---------- Post added at 04:26 PM ---------- Previous post was at 04:00 PM ----------
More pics:
picture.php
picture.php
picture.php
Ok, first the pics ...
Before:
picture.php
picture.php
After:
picture.php
picture.php
picture.php
Looks like ass! Take it off and put on a 3" BL!!!! :D
J/K Looks awesome! Hang in there and give it sometime and see if you can figure out the ride issues. I'm sure Tony can get ya fixed up with figuring out the issue with that. :waytogo:
---------- Post added at 03:31 PM ---------- Previous post was at 03:30 PM ----------
Next thing you should do is trim the exhaust pipe up so that it doesn't stick out so far. It's lookin' really good, Soulsea!
Modded
That Guy
1. Probably because of not being aligned the steering has gone to shit. Every anomaly on the road is pulling the car.
2. There's no way to describe the ride as anything other than donkey. Perhaps my expectations were unrealistic, perhaps it's not a good idea to have these drops on city roads, whatever the case I drove 3 miles and my kidneys are already sore.
3. I have rub in the rear part of the front arches at half lock and sometimes in reverse.
4. The pic above doesn't do the look justice because dropped as she is, she looks absolutely stunning!!!
So I don't know what to do. I'm not going to start cutting up trim to relieve rubbing because I want to be able to sell this truck at some point down the line and I'll have to put it back to stock. And I don't know what to do about the ride situation. But I love the way she is sitting.
Truth is I am more depressed than happy as it seems this kit will have to be taken off so as to save my truck and my back. :(
Main point: Your Tahoe looks way better!!!:party33:
1. Don't wait much longer to get an alignment unless you want to end up buying new tires. After a spindle install the alignment is always nasty and causes the car to pull. After you get one it will be back to stock. That pull causes excessive scuffed treadwear, which = not good.
2. I can't imagine the ride being bad as long as you have a spindle drop and shock xtenders. Could be tied back to the alignment maybe.
3. You should be rubbig there with a 2" drop on a Hybrid, which is slighly lower than a stock Tahoe. Just trim the wheel liner area where you see the scuff marks on it caused by the tire rubbing on it.
4. I know it looks even better in person so don't take it off because its rubbing the wheel liner, just trim the area its rubbing on. It won't require much trimming in a way that would effect the car sale down the road. With all I have trimmed (have just about no front wheel liners) I bet nobody would care when it comes to selling it. Look at my sig, if its not rubbing its not big enough, or low enough. :D
soulsea
Bar
Hi Neo and thanks,
Quick Q ... when you guys say 'trim' do you mean actually cut off part of the liner or do you mean sand it down till it doesn't rub any more?
---------- Post added at 06:48 PM ---------- Previous post was at 06:12 PM ----------
Oh and about the ride quality ... the best I can describe it is that it reminds me of the 88 Wrangler I drove in college. I had a key fall off my keychain in the ignition whilst driving back from the shop today ... granted the keychain ring was loose but still. :(
THE YETI
South FL
something certainly isn't right... get it aligned and go from there. Make sure you take it to a reputable alignment shop, not just a regular shop that does standard alignments. The vehicle is now lowered and needs to be aligned at a shop that knows WTF they are doing...
The way the truck rides definetly sounds way off.
NORCAL SS
SUV SUSPENSION GURU
Before:
picture.php
picture.php
After:
picture.php
picture.php
picture.php
I'll take better pics a little later on level ground and when the sun comes out.
Now, I need to express a couple of thoughts on this because I don't remember the last time I was this happy and depressed at the same time ... keep in mind I haven't done the alignment yet.
1) if the truck is not aligned it will drive like crap
2) i just want to be sure you didnt have autoride on the truck. You thought you did shop said it didnt so not sure on that one
3) like people have done before on teh bigger wheels trim rear plastic wells there is no problem
4) is the back bottoming out? did they put the shock extenders in? Did they cut teh bumpstops down?
There are a few things we need to go over. the 5305 are great springs only other thing there is to do is get new rear shocks but i really want to make sure if your truck has or doesnt have autoride.
We just need to over a few things and there is a 1 inch spacer to put in the rear also which will bring it up one inch. before you get all depressed relax..... we can get you rolling fine again.
---------- Post added at 04:27 PM ---------- Previous post was at 04:24 PM ----------
25mm offset is a issue but ive done tons of these trucks and no issues with ride on here and locally ive istalled.
B
B.G.
Looks dope man:Handshake:... That sucks that your having those troubles. I couldnt imagine the ride being that horrible, especially after all the rave reviews posted by Tony and others with lowered Tahoe's. Def get your alignment and report back. Im really diggin the way it came out. I think im going to go with a 3/4 though. The front sits a lil too high for me... Snowplow here we come:hands:
soulsea
Bar
- On the autoride topic ...
The 2010 LTZ specs page it says autoride ... on the 2010 Hybrid specs page it says the suspension is "Premium Smooth Ride suspension." The specs for the 09 and 10 are the same and I assume if the Hybrid had autoride it would say so. :think:
- I am not bottoming out, at least not so far. It's just that the ride is incredibly stiff. Could that be attributed to not being aligned?
THE YETI
South FL
Tony.. just out of curiosity, could his back end be riding bad because of the weight of the hybrid system? I don't know shit about Hybrids, but I thought they have batteries in back, maybe they are heavier back ends than our usual tahoes? Just brainstorming...
---------- Post added at 06:34 PM ---------- Previous post was at 06:33 PM ----------
Check if your rear axle is sitting on or close to the bumpstop in back? If it is, it needs to be trimmed way down to allow more axle travel. i'll let Tony confirm that...
soulsea
Bar
Btw, I just wanted to note that this isn't Tony's doing or fault, his kits are proven to work and as is evident, he stands behind his sales.
Not many peeps are doing what I'm trying to do on a hybrid so this is a learning curve for all of us. A learning curve on my dime :) but valuable lessons are being learned as we speak that may benefit me, Tony, and any other potential mod-head who may want to undertake this on this model.
THE YETI
South FL
Of course this isn't Tony's fault! If anything, he's the solution to the problem! I'm sure he'll chime back and make all this go away! :)
NORCAL SS
SUV SUSPENSION GURU
Ive lowered hyprids so nothing new but somethings up and lets try to figure this out.
little background on the kit you have in rear.
5305 (spring in there now) is the 5 inch rear coils from the earlier 00-06 tahoes. in 07 belltech set the 5305 on the subuarbans and yukon xls. The spring rate hands down is better on the 5305 than the ligher duty 23323 kit (which they have listed for the non autoride trucks) I dont even use the 23323 since the 5305 is better.
Soulsea can you do me a favor measure from ground to fenderlip on your truck all around as it sits right now on 295 35 24 tires.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
1st off, That Looks Amazing. As far as alignment. the Tie rods had to be removed to install spindles. Anytime this is disturbed, Alignment is a must. Its not going to feel better until you do. My ride quality isnt bad. But im not rolling on 24 either. Im on 17s and hopefully by next weekend, it will be 22. Hopefully the shop Installed the supplied 1 inch spacers as without them, probally would make the rear sit too low. Also hopefully they also installed the supplied bump stops.
soulsea
Bar
Sure ... it's 34" on both rears and 33.5" on both fronts.
NORCAL SS
SUV SUSPENSION GURU
no prob
Can you see how much space you have between the bumpstops and when it hits on the axle pad?
also honestly the rear came down a nice amount im sure stock shocks are not up to their task causing rear to not ride great and sloppy. Lets see how much space you have between the bumpstops and when it touches the pads then we can go to the next step.
i know for the smooth ride suspension valving is great for stock height when you lower its not the best at all.
soulsea
Bar
Mmm, you are now crossing into territory that I am unfamiliar with as my mechanical knowledge and vernacular are limited at best.
What do bump stops look like, what is an axle pad, and where do I go to measure?
Ugh, I feel like an ass but I honestly don't know these things. :(
(btw, I have to do it in the morning cause it's night here)
NORCAL SS
SUV SUSPENSION GURU
ok in rear there are new bumpstops they give with the kit they look like the circle orange things here
now those things are above the rear axle on the frame. now i need to know the space from the bottom of them until it hits the bumpstop pad right below them which is on the rear axle
on the frame looks like this
If they used the stock ones it will just ride on them or if they are close to the pads now you can cut off some of the yellow lower part and will give you more clearance. Just need to know how much space we have to work with.
johnsonwillie199
