Tahoe Stock height with 22s PICS????
crazycrew
Vacherie, LA
Here ya go!!! 100% stock, except for the tint!!
Sierra53
Stock height with Factory 22's and stock tires.
For 22's oem esky's is where it's at IMO!
Jshlafer
Thinking about a 2/3 drop... running 22's.
Should I drop lower?
For my tastes....2/3 or 2/4 is about as low as I'd want to go on a DD but that's just me. You'll get a wide variety of opinions on that, though. With that said, I'll be doing just a 2" rear drop on mine when I get rims.
I could live with a blank cap, though...
chadman
does going from 20's to 22's make the tahoe any higher?
this is kind of a stupid question, but I don't know the answer.
If I went from 20inch wheels to 22inch, does it make the over all height of the Tahoe any higher?
I'm asking because I don't want to make the over all height any higher so it will still fit in underground parking.
soulsea
Bar
It will depend on the size sidewall you go with on the tires.
My stock rear height on stock 18s (road to floor of trunk) was 32.7, with 22s on it's around 33.5. The difference will be less going from 20s to 22s, again depending on tire.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
The recommended tire size for a 22 is 285/45/22 as a 20 is 275/55/20. Basically the hight won't change. If you don't up in the aspect tire ratio.
soulsea
Bar
Actually I removed my 3rd row seats so that could explain why my ass is rising. :)
Plus I never measured it on 18s so I'm just going on chevy specs ... all these trucks are a little different each.
So yeah, keep aspect ratio of tires and ride height will stay the same.
felixgun
Lafayette, LA
+1
Had factory LTZ 20s now factory 22s with those two tire sizes and it is very similar in height.
riso79
So Cal
blank cap or esky cap only though... i want the chevy cap... that's non-existent...
Here is a set that I bought on eBay. They also have a set with a raised emblem too, I went with the set that matches the grille bowtie the second time around.
need ideas for wheels/tires. thanks
Here is a side shot with the factory 22's and no drop..... yet.
Nice caps riso :waytogo:
veteran111
