Powered Seats
ferr1s
Naptown
Anyone know where the fuse location is for the power seats and what its labeled? I've looked under the hood and at the drivers side dash at the front door and I can;t find anything labeled for the seats. I have an LS and installed a pair of Leather esky seats. The original drivers seat was powered, so the new leather driver's seat is working great. The passenger seat was not, so now I'm having to figure out how to get it going. I figured I'd start with the basics 1st...check the fuses. I thought maybe GM didnt put the fuse in since the passengers seat didn't need power to start with. Any other thoughts are appreciated.
- Ferris
tahoe7689
you could have gotten a bad seat, it happened to me. I bought a used driver's seat and installed it, only to find it wouldnt move, so I put the old one back in and it worked.
Maybe try hooking up your old one just to check and if it works then you can rule out the fuse problem
ferr1s
ferr1s
Naptown
My original seat wasn't powered at all, so unfortunately I cant try that method. I guess I'll have to track a meter down and check power to the plug. I thought it might be easier to just check a fuse to see if they even put one in. Any other thoughts until I dig up a volt meter?
- Ferris
tahoe7689
Im pretty sure theres a fuse....I would recheck the underhood and drivers side interior fuse blocks. Both boxes have a map on the cover that tell you what each fuse if for, the seats should be something like "pwr seats" or accessories....not exactly sure what, Ill look at mine tomorrow and post back. I havent heard of anyone going from non-power to power, but if the drivers side works the passenger should too....Like I said though, you could have a bad seat. The voltmeter sounds like a good idea
ferr1s
ferr1s
Naptown
Chilton Manual
I've been looking through the Chilton Manual and that hasn't been any help either. Who knew that finding this fuse was going to take longer than putting the seats in =-)
I'll have to check for the SEO fuse after work tonight. Thanks for the info Scotty.
- Ferris
ferr1s
ferr1s
Naptown
I found an SEO B2 & SEO Ign under the hood. I also found an SEO Accessory in the passenger compartment fuse box. All three fuses were in good shape. On one hand, that's great. On the other hand, that doesn't help my cause.
On a slightly different note. It annoys me that my Chilton manual has yet to be of any real value to me on anything I've done or needed to do for this truck. I think in their desire to cover so many iterations of tahoes, silverados, suburbans, etc., that they've been to vague on topics. I will say though, that they do a great job of explaining how to take lug nuts off....well worth my $25 bucks!
- Ferris
OmarR
Indianapolis, IN
For 03+, it's the 30 amp breaker in the relay block. The relay block has the black plastic cover over it, left of the brake pedal.
ferr1s
ferr1s
Naptown
Checked the block for the relay. There is one 30 amp breaker in place labeled for a seat. Does this breaker operate both seats? Any other places to check for a breaker or fuse for the passenger sear? The seat worked great when it was removed before, so it has to be the power to the seat being interrupted.
- Ferris
OmarR
Indianapolis, IN
Ok, I just re-read your original post.
Since your truck did not originally come with a passenger powered seat, the wiring is not there, you will have to add it yourself.
At the power connector for the seat, look at the end terminal "A" slot. Since you bought a power seat, the seat half of the connector will have a thick orange wire. The truck half of the connector will be empty. You need to add a terminal and wire, and hook it up to 12V. If you pull the carpet back, you will see a wire loom harness that passes underneath the seat, towards the front of the seat. The orange power wire would have come out of this wiring loom. That loom contains the same orange wire that powers the drivers seat, and gets its power from the 30A breaker in the relay block. If you take out the DRIVER seat, and pull back the carpet, you will see the exact same setup. You just need to duplicate it on the passenger side.
Any of the following terminals will work:
GM #15304718
GM #15304719
GM #15304720
GM #15326004
The only difference is the width of the crimp end. I listed them from smallest gauge to largest, since I don't know which gauge wire you plan to run.
Also, depending on the year of the Esky donor seats, make sure the wires match up on both sides of the connector. Otherwise, you may have to back out the terminals on one side (truck side is easier), and re-arrange them. If they don't match up, you will get the seatbelt light, passenger airbag on/off message lit up incorrectly on the rearview mirror, and airbag error message displayed on the DIC in the cluster.
OmarR
Indianapolis, IN
OmarR, you are truly the man!!! Please don't ever leave here!! Stay forever!! :Handshake:
Thanks Riviera!! I did the same thing the OP is trying; I installed newer 6-way power seats, replacing my passenger manual seat, and I had to get the shop manual out and figure out why I wasn't getting power.
Good luck to the OP!!
ferr1s
ferr1s
Naptown
It''s alive!!!!
It Works!!!
First, I have to say thanks to all the guys who helped me track down all the various fuses, breakers, or relays that could've interupted the power to the seat. I have to really give Kudos to Omar though for giving me the details of how to get the seat working. Thanks a TON Omar.
TYF Members are the Best! :party33:
- Ferris
graytom1113
wire loom
i would like to say that wire loom is a big entertainment that provide the human being entertainment through the different source.Now the wire loom also comes in a few varieties which one is best to use is dependent on the level of ambition that involves your wire routing tasks
wire loom
shangboplastic
I think you might be mixing it up a bit . A wire loom isn’t really for entertainment — it’s mainly a protective sleeve used to organize and shield wires from heat, abrasion, and vibration. They do come in different materials like split loom, braided loom, or heat-resistant versions, so the best type depends on your application. For automotive installs, split wire loom is usually the easiest to work with since you can add it over existing wiring without disconnecting anything. best bulk cable ties suppliers
briannorris
