I need to go lower!
foreverfalcon40
Ok, so its time for tires, and I keep getting envious of few people on here of how good their HOE looks lowered.
I have a raked look, want to go a little lower in the rear!
Current tire in the rear is a 305/45/22. I got some curbage damage on out outter tire from crappy shocks and heavy weight. I have since replaced the shocks. No bottoming out issues.
I have 305 width tire, I know I have to decrese, but not by too much. I need a tire to put the 500hp to ground!
Front tire 265-35-22 (Thats a little too skinny for my liking and rough for these NY rds, where both my two front rims are bent but nothing to crazy to through off the ride.
Rear tire I would like to go 40-45
BUT WHAT width?
All I have removed from the rear to lower it is the helper leaf.
Here is a pic of current stance
These are the best pics I have :(
What is the best way to lower the rear? Shackles or a Flip kit? What is the widest tire I can go with out shredding the outter edges of the tire?
LOVE to keep a 45 sidewall but smallest I am willing to go is a 40.
ff40
clean454
i had the overload removed and shackles and my 305's rubbed id go a 285 35 22
this was with a flip kit and i had to TRIM so much
foreverfalcon40
foreverfalcon40
I cant answer your questions but I like your hoe man. It looks sweet!
Cough Escahoe Cough
Thanks, alot of work...BSD...blood, sweat, and tears.
Building on a budget of money and time. Some luck too!
---------- Post added at 09:53 PM ---------- Previous post was at 09:52 PM ----------
going down
Damm sure
---------- Post added at 09:53 PM ---------- Previous post was at 09:53 PM ----------
going down
Damm sure. your one of them!
---------- Post added at 09:56 PM ---------- Previous post was at 09:53 PM ----------
Please define trim!? Have any pics? Were able to keep the inner fender trim to keep out grime?
I WANT to keep the Fender Flares, which I forgot, and you currently had.
35 tire is not an option. 40 is smallest I will go.
---------- Post added at 09:57 PM ---------- Previous post was at 09:56 PM ----------
What is overload? Did you remove your shackles or you installed lowering one?
clean454
i had drop shackles but i dont think they matter once u do a flip kit
the overload leaf the bottom fat leaf in the leaf spring pack
then if u want to go a fatter tire just do shackles and remove that lower leaf
dont do a flip kit if u want a bigger tire
and i had to cut alot like the whole inner fender got cut it looked like shit with out the flares on
clean454
heres some more
tuckn rear rims!
tuckn front tire
---------- Post added at 07:15 PM ---------- Previous post was at 07:12 PM ----------
and of coarse u can bag it :)
clean454
ya but he wants to run a wide tire...
---------- Post added at 07:20 PM ---------- Previous post was at 07:18 PM ----------
few more
front
tire!
ok ok im done consider it inspiration
texfoto
