98 tahoe, 2wd, 4dr. Need help determining why the ECM-1 fuse continues to blow. Wouldn't start after being parked for an hour. Found the ECM-1 fuse had blown; replaced fuse and it blew again as soon as I turned the ignition on. Checked fuel pump relay, tested good. put a test lamp in the fuse slot and sequentially disconnected the ECM, crankshaft position sensor, ignition control module, and ignition coil -- no joy; test lamp stays lit, fuses still pop. wires to CKPS, ICM and IC all tested good as well. Interesting find is that the test lamp goes out when the IGN-A 40A fuse is removed. Anyone have any ideas on what the problem is and how to fix?
Thanks
Thanks
A single injector non-oem will cost about $64 and the original design has been detrimental to the v6/v8 engines that use them. You have to pull the body of to get the injector out and at that point the bracket is not usable if you bend it to far to get it off. They start dumping to much fuel causing misfires among other symptoms and enventually wash down your cylinders and yopu start loosing compression. Besides one new against 7 old will not have the same flow rates. A new injector assy with all new injectors with improved design with new regulator already installed as well as new mounting bracket costs $215 at amazon. Auto parts store will most likely charge $450+ and you have to buy bracket seperately. Throw in the fel-pro plenum gasket in case yours is damaged and it is $230. It is from Delphi itself. Like I said you won't regret it.
