Transmission shifting weird issue....
Bowie
I have a 1997 4 door Tahoe with the 5.7L, she has 116,000 on her right now. The problem I am experiencing is mainly at freeway speeds but sometimes at lower speeds.
I am experiencing odd revving when Im at freeway speeds. it goes between 1900 and 2100 rpm and goes back and forth in there... like its searching around.
It all started with my cruise kicking out all on its own, and then cruise just stopped working. I have since pulled the fuse on the cruise but it has not helped.
The problem is sporadic, I notice now that sometimes it stays at the higher rpm now instead of shifting back down.
Could this be my Torque converter lock up.
What I have tried:
new Fuel filter
new MAF(Mass Air Flow) sensor
new airfilter
I have heard that the VSS (Vehicle Speed Sensor) could cause bad shifts.
Anyone have this problem and get it fixed?
Thanks
EastTXYukon
Longview, TX
I'll be interested in this thread because I have had some of the same issues in the past with my Yukon. At highway speeds and hot days, it was like my tranny was shifting in and out of overdrive sporadically. In OD at 70 mph I usually run around 1900 rpms, but my truck would randomly spike up to around 2100 rpms, even though I was on a flat highway.
Funny thing is that it hasn't happened to me since this summer. Seems silly that heat would affect this, but it hasn't been a problem since the outside temperatue has gotten cooler.
I'm anxious to see if it becomes a problem again when the weather starts to heat back up.
destroyer1362
A work in progress
Midlothian, TX
If your truck's temp is lower that a certain degree (I don't know what exactly) the computer won't let the tc lock up. If your thermostat is stuck open your truck could be running too cool and that could be the cause for your problem. So watch your coolant temp and see if you need a new thermostat.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If it is knocking out your cruise control as well then then common point between the two is the the brake actuation circuit. Get your self a multimeter and check for proper operation of the combo brake switch it handles lights/TCC/cruise control. It sound like your switch has malfuntioned.
B
Bowie
where and how exactly would I do this? Where is the switch and how do I know do I know what it means to be working properly?
Sorry for being so stupid.
Thanks,
Kyle
---------- Post added at 05:31 PM ---------- Previous post was at 05:29 PM ----------
What would that temperature be? The heat seems to work fine in the car so I am assuming the car heats up enough?
---------- Post added at 05:51 PM ---------- Previous post was at 05:31 PM ----------
A part number for that part would be nice. The dealer cant seem to find it.
SunlitComet
OBS Jedi-Do Good
Thanks,
Kyle
The dealer can't find a thermostat. WOW.
Brake switch is at the top of your brake peddle. At about $9 bucks from the dealer or amazon or part store just replace it. it is an ACDelco D1565E. you will need snap ring pliers and a 11mm (7/16 inch) socket to remove and install it. Should take less then ten minutes to do but I will have you disable the airbag system before hand. Another 10 minutes. You Can Do It. If you just want to replace it instead of getting your hands cramped trying to test it I will post instructions or diagrams. Let me know which way you want to go. Like I said this effects you tcc and cruise. Temperature does not effect cruise control operation.
EastTXYukon
Longview, TX
Hey sunlit, do you think the switch could be the culprit in my situation as well?
Sometimes my cruise control works, sometimes it doesn't. I usually just leave it turned off and don't mess with it. But, if that brake switch affects the operation of the cruise plus the torque converter control, do you think it is possibly malfunctioning or have a short in it?
B
Bowie
I would prefer just replace it. Instructions and picts are nice. Anything is appreciated. Thanks for all the help.
noJeepshere
Bountyfull, Utahrd
We have a winner!! My parents '98 Sub did the same thing, replaced the switch and all was good in the world.
SunlitComet
OBS Jedi-Do Good
Most likely. At any rate if you just started throwing parts at it. it is the most common and least expensive part to start with.
SunlitComet
OBS Jedi-Do Good
Remove or Disconnect
Negative battery cable.
Disable SIR.
Retainer from brake pedal pin. Use snap ring pliers.
Switch by unsnapping from pushrod.
Electrical connector from switch.
Install or Connect
Electrical connector into switch.
Switch by snapping it onto pushrod.
Retainer onto brake pedal pin. Use 11mm (7/16 inch) socket to push new clip on pin.
Enable SIR.
B
Bowie
What switch is the SIR switch, there seems to be a lot of wires down there? Is ther anything I can take out so I have some more room in there?
Thanks
raptorforme93
Tampa, Fl
Is this why my hoe never shifts at 50 mph when I have just started it on a cold day? I get up to 55 or 60 mph and it doesnt shift until the truck has warmed up to normal temperatures. I figured that it was something like what you said but I was never really sure or cared much to ask since it always shifted once it was warm.
SunlitComet
OBS Jedi-Do Good
Bowie: with key out of ignition lock pull your airbag fuse. #8 I think. Then disconnect the only the yellow colored connectors under neath the dash. At least one but maybe two if your have passenger air bag. Proceed with repair. Reverse the procedure to re-enable SIR system.
Don't want you to get hit by a false airbag deployment. :)
---------- Post added at 04:51 PM ---------- Previous post was at 04:47 PM ----------
Raptor, iirc the temperature can kill off the overdrive gear as commanded by the PCM. You should be just fine. It is SOP in the PCM. Good enough or should I find some details for you if possible?
EastTXYukon
Longview, TX
Wow! Learning a lot today. My truck does the same thing as Raptorforme93's. I thought it was a problem, but just one I had to deal with on a 15 year old truck with 150k on the transmission. I had no idea that the tranny not shifting into overdrive until it was warmed up was the correct way for it to operate
Thanks for the info Sunlitcomet :beer:
B
Bowie
sunlitcomet
I wanted to say thanks for all the help. I could not have done it without you. It has been running great so far, hopefully it keeps up.
The one question I have is: Did I do any damage to the Torque Converter. The tranny had been shifting like that for 5 years or more.
Thanks again
raptorforme93
Tampa, Fl
No youre good man :) Thank you though! I figured that it probably wasnt a big deal since everything drobe normal and it did it consistently until the weather warmed up. Thanks!
SunlitComet
OBS Jedi-Do Good
sunlitcomet
Thanks again
Ouch. Maybe some extra wear and tear on its clutch. five years is a long time. If you do get a code for a or notice slipping tranny you will know where it is slipping. Just run it till it breaks.
crxx
tn.
had the same problem and such an easy fix! Amazing how a lil $10 switch could handle so much. And thought i was gonna need a new tranny....smh
insadj05
Iowa
Additional questions
Sunlit,
I was driving home today with the 99 tahoe and the rpm's were drifting between 2100 and 1900 like above. However when I pulled off the interstate for the 14 mile back woods trip to the house every I stopped and started I would get hard shifts. Would this switch be causing this also?
Thanks
Buford bubba
