Steering wheel trim
T
TX LTZHoe 07
Weatherford, TX
Yes, thats my question as well. And how good are they. Looks like the replacements through GMparts is about $35 each side...so, am I really getting something as good for the $55, or is it just a cover?
zach2011
Platinum Member
Where are you seeing the $35 ones? Only ones I can find are $67 each from GM Parts Direct; unless you are checking a different GM Parts site.
T
TX LTZHoe 07
Weatherford, TX
Try part numbers 25824700 and 25824698. It says that they are the brushed finished steering wheel covers.
That's $86 total, which includes $21 worth of shipping and handling...YOWZA!!!
Thats at GMPartsdirect
felixgun
Lafayette, LA
How do you pop off the original steering wheel covers? I'm about to order the brushed aluminum ones from GM Parts Direct.. thanks for the info!
zach2011
Platinum Member
You have to remove the steering wheel airbag cover. Do so by disconnecting the battery first. Then, there are 2 tiny holes on both left and right sides of the steering wheel, you will have to put some sort of small allen key in there to press and release the clip inside, do that for both sides. Then the cover comes off and I think there are 1 or 2 screws holding the little covers in place.
ChevyguyArmen
Scott, LA
i just got my brushed aluminum steering wheel trim covers. i installed them right on top of my black ones which were peeling like crazy. I have a 07 Tahoe LT. They look ok. Def does not look factory but better than the peeling black. I don't know if I will keep. I may order the Gm ebony or brushed and just change them. I didn't want to mess with the air bag.
felixgun
Lafayette, LA
I have an 08 LTZ and my steering wheel cover was also peeling. I ordered the Factory OEM replacement brushed aluminum steering wheel covers that come on the 2010-2011 LTZ Tahoe's and have been coming on the Denali/Esky's. It's a replacement, not a cover, so you retain the "factory" look. Gmpartsdirect.com about $87 shipped If I remember correctly. Well worth, IMO.
felixgun
Lafayette, LA
wrong place to post this but no, it's not worth it (to me at least...very few digital radio stations in my area). google your local hd digital radio stations first if you don't you'll be stuck with two digital stations that SUCK like me.. in a few years i'm sure i'll use this more as more radio stations will turn digital
---------- Post added at 03:05 PM ---------- Previous post was at 03:04 PM ----------
friend's got an esky and i was looking at this.. it seems like it's a lighter colored brushed aluminum...it's so clean...
zach2011
Platinum Member
It'll only look good in light interiors, if you specifically mean the Platinum version. it is a "warm" aluminum color.
ejschultz
NW Indiana
Let's revive an old thread here...
Anyone ever remove the stock ones, peel all the finish off, then re-coat it with something else? That's my plan. I'm just wondering because I want to find out the easiest way to peel it off. It seems like it's very poorly applied plastidip the way it peels in small pieces if I pick at it.
NathanJax
Vacation Nathan
Jax, Fl
Yes
just like you're thinking. picking with your hand/fingers.
briannorris
