DDM Tuning Ballasts Acting UP
oakrdrs187
Coachella,CA
Can someone explain what is happening to me?
I have 55 watt slims on my lows and 35w full size on my fogs, and basically my problem is that the passenger light fires with the rest but cuts out right away. This only happens when the truck is running, Ive tried it many times when truck is off and all come on just fine, but when truck is on it always misses on the first try.I have sent it in and everything checks out, it's kind of weird.
All the ballasts are wired with heavy gauge wires for both power and ground, and with relays. Which is just like using their Harness.
DenaliAK
Colder than you
Alaska
What I'd do:
Try another bulb to see if it duplicates. If it doesn't, it's the bulb. If it does, see the following.
Try switching ballasts with one that fires normally and see if it still does it.
I bet it won't.
If it does, check running voltage. Maybe you just have too much on at the same time and it's too much draw when you fire them all up?? Just guessing, although I'm laying odds on either the bulb or ballast.
Also, when you say it's wired with heavy gauge wire, is it wired directly to the battery for power or just to the stock wiring? Sounds like a dumb question, but I've seen people do interesting things.....
vipergtsr96
I hate it when that happens, you know I see alot of people with HID fogs and lows and whenever I see them turn them on, all four of their lights kick on together with no problem, and it I ask why cant I have that, is it too much to ask? Did I do something wrong?
oakrdrs187
oakrdrs187
Coachella,CA
I have tried moving the ballast, around, another bulb, same thing.
I thought too maybe I had too much going on, but theres no system in my truck yet, except stock bose, and I have an optima redtop. What really throws me off is that it does it when the truck is on and the voltage is in the high 14's, and it works perfect when off in the mid 12's. And my heavy gauge wiring is from battery to relays to ballasts, there is one 8awg from battery split into 2 12 awg for each relay, one fog one lows, and then to ballasts. Only thing I use stock wires for is for relay triggers. Im thinking the guy at DDM was right, he said that the digital ballasts are picky and need 12Volts at just the right time. What about putting in a diode on the relays, maybe the lights are getting some wierd feedback?
DenaliAK
Colder than you
Alaska
Damn. Sounds like you've done everything possible right, but the DDM guy is probably right. You might be pushing too much power at first. 14 volts is a bit on the high side for auto electronics. Most things can function, but some get picky. A simple resistor might solve the problem?
I'm not a super-electrician, so I'm half stabbing at this....anyone else with thoughts?
jutte73
Dayton, OH
so your passenger light fires then goes out, ok. you switched the bulbs and passenger light still acted up? you swapped the ballest the passenger light still acted up? if thats what going on i would go one step deeper and swap the relays. from there check your resistance of the wires from the resistor to the relay on all four and make sure all the numbers are close to the same.. maybe a bad wire or conector/connection somewhere in there... just a thought..
oakrdrs187
oakrdrs187
Coachella,CA
The guy at DDM said no resistors, Digitals don't work with them. I'm flabbergasted...LOL. First time using that word in a sentence.
The polarity checks out, cuz I purpously switched it and it wouldn't fire at all.
As for checking resistance on everything, I think it's worth a shot.
Any thoughts on those diodes to solve this? Relays don't buzz.
chip
Cincinnati
I have 6000K HID fogs and they do the exact same thing. I've been trying to figure it out forever. It doesn't seem to be the ballast, bulb, or wiring. I'll let you know if I figure it out first.
chip
Cincinnati
In the off chance that an electrical engineer happens across this thread; I have noticed that this is only an issue at initial startup, when the driver allows there to exist, a pause between "ON" and "Start". When you are aware of this, and quickly turn the key directly to the "Start" position, it's never a problem.
chip
Cincinnati
Not me. Mine only fails (that I know of) when I turn the key slowly, and allow that pause to exist.
I've also noticed that the left and right side burn at different brighnesses (like your sig pic).
oakrdrs187
oakrdrs187
Coachella,CA
Actually I need that pause for all of them to fire, allow 1-2 secs of warm up and then start, it's the only way I get them to all go. It's the weirdest thing, them problem is occurs when the truck is running. So for example, starting it quick as you mentioned will cause it to happen because the truck is already going.
That's not my current setup, those HIDS were the reason I got DDM 8000k 55W, they were too blue for me, and not burning same color, but they started up just fine, with truck off, on, on it's side.
I'm gonna update SIG in a few.
UPDATE:
I have swapped relays, tested connections, and just plain used factory wiring directly to the ballasts, and still having the issue, although being plugged in to the stock harness it doesn't do it as often, it went from doing it every time to about 1 every 5 tries. I have yet to try the diodes on the relays, been kinda upset, since I lost my $300 cordless impact.
chip
Cincinnati
UPDATE:
I should have mentioned that. Mine will also fire just fine if I take an extended pause between "On" and "Start". It seems to me that the body's natural speed for turning the key causes the perfect disruption in firing. I still can't understand why one side seems to burn brighter than the other though. The one that burns least is also the one that will fail to fire. I have my stock wiring going to my ballasts.
SuburbanPassion95
