rear lower control arm mount
candyman74
arnold, mo
my tires have a groove cut in them from rubbing on the lower control arm front mount. the tires are 305 35 24s on some 24x10 boss 313s. the truck is lowered with a mcgaughy 2/3 kit with spindles. i have 1/4 inch spacers on the wheels and had to also cut the upper shock bolt and take the inner wheel well plastic off. i know im going to need the pan hard bar since the drivers side rubs more. could i use some thicker spacers or is another way to solve this?
thehoe92
fo sho
The916
skinnier tires..
I run the 295/35/24's on the same rims and I don't rub anything
candyman74
candyman74
arnold, mo
is your rearend offset also? i saw the panhard bar on steves video i think thats going to be next.
NORCAL SS
SUV SUSPENSION GURU
i have like 30 panhard bars in stock 139 shipped if you see it for less ill beat it. its the spohn ones either red or black.
Grocery Getter
A guy with a truck.
Phoenix, Az
Are you sure it's the lower? I bet it's the upper.....I have the same problem but I run 285's. You definitely need to run slimmer tires try a 285 or smaller. As you go lower it gets worse since the axle moves forward in the wheel well as you go lower, I have a 6''+ drop in the back and when I air out my bags the tire is pretty much touching the front of the wheel well. I just installed the Spohn pan hard bar and it helped a lot and gave me the ability to place the rear end where in needs to be in relation to the LTA/UTA and fenders but now the issue is centering in the wheel well. Spohn is getting ready to release adjustable upper/lower trailing arms for our trucks and that will solve my problem. Do you have the lower tailing arm relocators?
NORCAL SS
SUV SUSPENSION GURU
trailing arm relocators push back the axle are you guys running these?
NORCAL SS
SUV SUSPENSION GURU
I am..........only good for about 6''......when it's dumped I'm in a bad place.........
yup spohn uppers i allready have the adjustments for all that. Run more negative angle also which i will be releasing all that info since ill have the first bars here in about 2 weeks to sell.
Grocery Getter
A guy with a truck.
Phoenix, Az
Nice. Post up when you get them and I'll grab them from you instead of Spohn as long as you match the price...and I know you will:)
candyman74
candyman74
arnold, mo
im not using those but i think if i get the panhard bar and run smaller tires i should be fine but ill check out those trailing arm relocators though
---------- Post added at 02:54 PM ---------- Previous post was at 02:42 PM ----------
do you offer those on your website cause i have looked and cant find them
NORCAL SS
SUV SUSPENSION GURU
my prices are allways lower shipped just like on the trailblazer ss spohn items or any spohn items
NORCAL SS
SUV SUSPENSION GURU
once i have them in my hands ill put up pricing.
candyman74
candyman74
arnold, mo
ok i found your trailing arm relocator mounts on your website, my bad. now what do you do for the front of the rear trailing arms, i have seen a few where they have another mound under the frame. do you offer those as well? thanks
candyman74
candyman74
arnold, mo
update my bad after looking at the truck again it is the upper trailing arm. so the next thing is how do i take care of that cause its rubbing on both sides, drivers side more than passenger. if i move the rearend over with the panhard bar then the passenger side is going to rub. so would 1/2 inch spacers and thinner tires fix my problem
Grocery Getter
A guy with a truck.
Phoenix, Az
I thought so.....thinner tires my friend it's the only solution. The spacers will work as long as you never plan on lowering your truck below the fender because I don't think you'll be able to tuck with spacers....could be wrong though.
candyman74
candyman74
arnold, mo
thanks i need tires anyway so looks like next spring. what size should i go with 295, 285? wheels are going to get a powder coating also to match the truck.
Grocery Getter
A guy with a truck.
Phoenix, Az
I'm running 285/40's and it's tight...... If you don't mind less sidewall you could go 275/35/24(I think they make that size).......
048tahoe
