iPod integration Review: iSimple aka PXAMG (GM5) for the 03+
Eagle
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
no, ipods work fine.
we both have a nano and an iphone.
jmyler
atlanta
Oh cool. i might see if i can't find a cheap 160gb and leave i in the console then. Thought about doing that in the first place.
Eagle
Eagle
EL PASO, TX
UPDATE: 8/9/10
I have read that the newest batch of PXAMGs now include the IOS4 jumper board factory installed. If you are looking to purchase an Ipod solution, this is IMO the best device on the market.
I only wish it had scrolling text.
If yours is more than a month or two old...
Unfortunately, the without the ios4 authentication board, a PXAMG connected to *any* device running iOS4, continuously produces the dreaded "accessory not supported" error until it's disconnected.
So... don't update to OS4 until the fix is procured.
You have to purchase an authentication jumper from PAC
Info:
http://pac-audio.com/productDetails.aspx?ProductId=276&CategoryID=36
Jumper:
http://www.pac-audio.com/productDetails.aspx?ProductId=1003&CategoryID=22
Install video
[yt]9uo_YNlrfW4[/yt]
jmyler
atlanta
Thanks for all this info eagle i really appreciate it.
zaksgsr
Clearwater
Thank you for posting this information. Since Apple changes their iPhone format on what seems like a yearly basis we have to update the product all the time. If anyone else has this problem please contact AAMP of America at:
http://aampofamerica.com/web/contact-customer-service.asp or via phone at:
1.800.477.2267 x285
Also check out the operation videos (iPod, iPhone, Bluetooth, HD Radio, Sirius, etc...) for GM vehicles at
youtube.com/peripheralelectronic
mech5700
Boca Raton, FL
i use an ipod touch.
just to clarify, when hooked up to the pxamg with ipod, you cannot access the music library on the ipod itself, it can only be controlled thru the radio?
also, when navigating thru menu's to change artists or songs, the current track continues playing until the new track is selected, correct?
reason why i'm wondering this is because i installed a usa spec pa15-gm. it works great, but when scrolling thru artists or albums thru the radio, it begins to play the first song in the folder. like if i'm scrolling from As I Lay Dying to Metallica, it starts to play the first track in the Bad Company folder, CCR folder, Dethklok folder, etc etc until I stop turning the wheel when I get to where I want to be.
BUT, what i think is better, is that I can switch to "direct" mode and navigate thru the ipod's menu itself which is much quicker than going thru the head unit.
i think that both unts, pxamg and pa15-gm do just about the same thing, but both have their annoyances...
if the pxamg allows access to the ipod's library on the ipod it self while connected, i think i'm gonna switch to the pxamg. that way i can have better interface thru radio and be able to use the ipod menu itself.
jmyler
atlanta
With the PXAMG you can also chose whether or not you want to control from the ipod or the radio. There is an aux also that comes with the PXAMG so you can plug anything in that has a headphone port. That connection is AUX2, if you switch to AUX 1 you get control of your iPod, switch to iPod and the radio controls it.
That thing you mention about the first song in the folder playing doesn't happen with the PXAMG you can scroll around while another song is playing and it will switch just when you chose it.
If you want to switch i'll give you a good deal on a brand new in the package PXAMG with wiring harness. Here is the thread http://tahoeyukonforum.com/forum/showthread.php?t=20040
I had one in my yukon for a while and the first time i tried to use the AUX cable it was staticy and would cut in and out as i moved it around. I sent the entire unit back and they sent me a whole new unit with the correct wiring harness and i no longer need it.
mech5700
Boca Raton, FL
I called PAC tech support today and they told me the same thing you did about switching menus without losing the current song so I went ahead and got the ISGM575 from Cartoys for $169 and put it in. Navigating thru radio to control ipod is WAAAAAY more refined and easier than doing so with the USA Spec PA15-GM. Only thing I dont like is having to hit Band 5 times to get back to the XM channel to switch to AUX1 to switch to using the ipod controls. Whereas the USA Spec, all I had to do was hit preset 5 to go to direct control of ipod. The USA Spec is also a metal box and seemed to have a little bit more quality with the connectors, PXAMG is plastic and I thought the connectors were just a tad on the chinese side. Oh well, the PXAMG is close enough to bein perfect.
On a side note, anyone hear just a teeny tiny bit of alternator whine when either paused or on AUX2 with nothing connected? I hear just a little bit, called tech support and they said take it back and switch it out, if still there it has to do with my truck.
The best thing about all this trouble is that after I removed the USA spec module to return it (which connects into the XM module instead of the back of the radio) I now have a fully functioning, all channels available, XM radio (which I never ever subscribed for). No idea how the hell that worked but hey, can't complain.
And for jmyler, thank you for your offer, but I just decided it's be worth it to just buy it local and have warranty and the ability to return it for whatever reason...
jmyler
atlanta
Wow I'm glad you mentioned the XM thing I tried mine out this morning and sure enough I have free XM too! Score!
mech5700
Boca Raton, FL
LOL wow I wonder why it does that? I lost my XM today tho.... someone on here musta ratted me out! lol jk...
But anyways, yeah PXAMG all the way. CD player took a dump n this is by far the best option to go with besides puttin an assload of cash into a new HU and all...
Eagle
Eagle
EL PASO, TX
well guys it has been a while, but a small update.
i havent even been IN the tahoe for a year now, nor do I have an ipod (it got lost, then found, then apparently stolen or lost again) anymore, though the kids now do. Priorities, you know!
However, my ex reports that PXAMG doesn't recognize the IPOD port anymore for the last few months on the head unit.
since she never allowed me to get her the $35 ios4 update chip, she was using the aux 2 headphone jack for the iphone anyway.
If I am ever allowed to work on the thing again, (ie she gets frustrated enough to let me take it apart) I will try resetting the module and see if that corrects the non-detection issue.
Sorry to not have completed the Ios4 update for you guys as i intended, but if she wasnt going to let me install it, why buy it? Lol :)
scribble
The one question I see no one has asked and I am guessing because they aren't using on is.
What is the lag on start up with the ipod and also when changing songs or playlists.
I ask as I have had several different HU with iPod adapters but got tired of waiting for them to get everything running every time I started the truck. I might be alone in this problem as I run a 120gig classic with all my music on and I also have a Nano 4g for quick setup or workouts.
Eagle
Eagle
EL PASO, TX
3-5 seconds tops
btw, i finally got the chance to unplug the pxamg on mother's day, and that fixed the issue with non-detection. so it is as good as ever.
saw on the 4th ex had her nano back in the tahoe again and is happy with it again.
scribble
Have you ever had problems were it would not play the Ipod again after restarting the truck until you unplugged the ipod and plug it back in.
I am using a Classic 160gb 5TH GEN
jkhuntzinger
