03 Taho HID help..
bkboatnsleds
McHenry, IL
Can someone dumb it down for me?
LoL I read good things about DDM's products.. Whats better DDM or HIDGuy.net.
And either way what would I need to do High Lows and Fogs on a 2003 Tahoe.
Would this be correct?
3 Kits total?
Low Beam 9006
High Beam 9005
Fog 880
So I need HID Harness or an Error eliminator? for any or all of the kits?
THanks for the help!!
DIY_DAD
So Cal
HID's
Im not sure about their prices, but i just did my 2002 ** with HID low beam and fogs....high beam coming soon with hi/low relay harness....anyways check these out on Ebay theyre cheap and INCREDIBLY EASY to install...i never did it before and it took me about 10 mins to do the fogs and 10 mins for the lows...i was so happy and still am...this company i the link above has the 9005...9006...and 880 fog light HID's for any tahoe and and wattage and color you want...i chose the 6000w cuz its not colored its just like a super white.light blue...it looks AWESOME imo!....private message me if you want any more info ...or ill have pics soon
---------- Post added at 11:30 PM ---------- Previous post was at 11:27 PM ----------
Oops forgot to insert link haha http://cgi.ebay.com/ebaymotors/ws/e...0496785280&viewitem=&sspagename=STRK:MEWAX:IT
by the way...i didnt need any harness or anything else, besides what came with the kit, to make them work
---------- Post added at 11:32 PM ---------- Previous post was at 11:30 PM ----------
blueflamed03
Oklahoma
IMHO, get the relay no matter where you buy, and get fogs and lows, chances are you'll never use the highs honestly. On back road trips, I use fogs and lows, MORE than enough.
adzam
New Jersey
From what I have read DDMs kits are good. Some people have had some issues but their customer service will take care of you. I have DDM HIDs in all my lights except the highs. The highs have a cheap eBay kit that I will soon be replacing with a DDM kit.
You will not need the error eliminator, but I recommend the wire harness for your lows.
HID highs are nice because they are super bright but keep in mind that HIDs take some time to get to their full brightness so when you switch on your highs it will get darker at first, not brighter. If you are going to do your highs I would recommend also doing the 4-high mod.
WHITEOUT
Dont Hate-Appreciate
Phoenix
I recommend some OEM Matsushitas or Osrams, what I have experience with, and love them and they are meant to last. I like to use the factory stuff personally. Sounds like alot of people like the DDM kits tho. LIke everyone else, get the relay harness, or do it yourself with 40amp relay, fuses, and wire. Just picked up a set of OEM Osrams ballast from an 08 escalade, locally for $20 at a junk yard, for my highs. IDK why, don't use them much, but might as well.
DenaliAK
Colder than you
Alaska
I know why....because you can't say no to $20 OEM ballasts. That's outrageously low-priced. I'd have gotten them too, even though I currently have an extra set of Matsushita's already...lol.
WHITEOUT
Phoenix
But you know what's up DenaliAK, I know you run OEM Matsushitas!!! And I paid crazy prices for my other two Matsushita sets!!! So who could pass up on that price!:gr_grin:
NoPh33rRaCiNg
Kent, WA
The error code eliminators are for BMW's i believe. You don't really need relays for the kits unless your run the 55w kits. 35w you'll be fine but its personal choice. I have DDM in my lows and fogs for a year so far no issues. I'd go with them over ebay kits, lifetime warranty through ddm and the price is great.
WHITEOUT
Phoenix
In most cases, you won't need a relay. But personally, and that's just from experience I have with HID's. I would always run a relay, just for the protection it gives and why not. Cheaper then a new ballast!!
SFBerto415
California
I have been doing a lot of research through and through the tahoeyukonforum and I can not find the answer to my question regarding HID's in the Fogs. And since WHITEOUT and DenaliAK in my opinion have a lot of knowledge with HID's then I will ask a question.
I have just upgraded my HID Lows from the 35W Ballast to the DDM 55W and am going to use the 35W for my fogs. I order the 880 HID bulb from DDM and attempted the install. Here is my problem--it seems that the 880 HID bulb is too long for the fog light housing. How do I over come this problem?? I have heard of a spacer, but i can seem to find a pic anywhere and I have also PMed other forum members and they so far have not come across this problem b/c there 880 HID bulbs fit perfectly fine.
Any help is greatly appreciated...I was kinda looking forward to installing the HID fogs over the Thanksgiving holiday.
NoPh33rRaCiNg
Kent, WA
What is it hitting? The reflector or the lense? I'm not sure if denali's have reflectors in theirs, but my tahoe did and i just stuck something in the hole where the bulb goes and pushed the reflector about 1/2'' for my 880 bulb to fit.
92__silverado
On my 2003 tahoe I just did the ddm HID fog lights in brand new housings. The bulb did not hit but it is VERY close. Is it possible the bulb holder for the lows and the fogs is different maybe causing the bulb to sit deeper? You could always do like NoPh33r said and just slide a pen or something in there to bend the reflector away.
DenaliAK
Colder than you
Alaska
Do you have the round fog lights? Not sure why the bulbs would hit anything if so. Mine clear just fine. If you have the rectangular fog lights that's another issue. I haven't ever worked with them, so I have to defer to others on that one.
Sounds like you can bend the reflector a bit to make it fit, although I don't want to think about how that effects your beam pattern. I'd avoid spacers of some kind unless you can get the bulb pretty well sealed in. Moisture has a tendency of finding it's way into the fogs.
1lowhoe04
Fort Worth Texas
On all our Chevys under the hood are the major fuses for your lights I have to take pictures of it but I ran a diod (die-ode) lol and I run my high low and fogs 6k all the time no problems lol besides the other ppl flashing there high beams at me and the occasional middle finger ! If your in fort worth texas area hit me up I'll deff show y'all how to do it 817-368-9984
92__silverado
I have square lights on my tahoe.
Those are actually relays under the hood, there is a write up on here on how to do the 4/6-high mod with that method.
I had it done for a while but have decided to go with a relay to do the same thing, I was worried about the chance of something in the under hood relay box going haywire and being stuck somewhere with no lights.
DenaliAK
Colder than you
Alaska
Tahoe...ok. Square lights. I knew that but wasn't sure what you had. It helps if I read the whole thread title... Lol
polobuds
East Bay, CA
You might want to check out this thread that I posted on:
http://www.tahoeyukonforum.com/forum/showthread.php?t=19188&page=2
I had the exact same problem. Ordered 35W 880 HID bulbs from DDM and installed them in new smoked fogs. The 880 bulb was a lot longer than the stock bulb and was hitting the reflector in the fogs. Some people on here had the same problem, and some removed the reflector, and some just stuck the bulb in and it didnt affect anything. I did the latter and just stuck the bulb in. It is touching the reflector and has bent it slightly, but other than that, it has been working fine. Although I'm not 100% sure it isnt affecting on-coming traffic because everytime I have my fogs on, I get people flashing me as if I have my highs on when I dont (i have stock bulbs in).
880 vs stock
DDM 35W 6000k 880 bulb installed in smoked fogs
johnsonwillie199
