Cold? Viper 5701 2 way car alarm $102 Reg $499! I GOT ONE !
Riff Raff
Arlington,Tx
Does anyone know if I can have the system installed using just the 1 way remote and sync the 2 way remote up myself when I receive it?
I'm 99.9% you can install it with your 1 way remote,and when yuo get your 2 way in just program it heres how to program any remote:
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key
Remote should be program
---------- Post added at 03:56 PM ---------- Previous post was at 03:52 PM ----------
Only problem I have is I still cant figure out how to lock the damn remote, getting tired of the buttons being pressed while in my pocket.
here you go:
To program the remote user features:
Press and hold the function button for 12 seconds: (at 3 seconds ignore
the Car number indicator.)
The remote emits one long beep, and the Transmit LED turns on.
This indicates the Main menu.
Press and hold the unlock
button for 1.5 seconds:
The remote beeps two-times, and the Transmit LED blinks
two-times and stays on. You are now in the Remote Configuration
menu.
The Arm, Disarm, Remote Start & Aux LEDs will turn ON, and/or
blink to indicate the current remote feature configuration. When
the LED is ON, the feature is ON.
To configure the remote control features press and release the
command button. The LED next to the button will turn On then OFF.
The remote beeps to indicate the feature configuration.
Lock Button: Auto-Button Lock.
When Arm LED is OFF, buttons will not lock.
LED ON: The buttons automatically lock 60 seconds after the last
button operation to avoid accidental Command operations. When
locked, if any command button is pressed the remote will emit an error
output.
If button lock is ON, press function, and then unlock
buttons.
diffrnt
Say...What!
MS
hey diffrnt how do you order from digikey ? i saw i can get 50 cr2016 energizer batteries for 15 bucks i think i can get 2 from autozone for 5 lol so thats a good freaking deal! but how do i order that site is confusing .....
Yea, the site sucks for ordering, but here is the link to the batteries: http://search.digikey.com/scripts/DkSearch/dksus.dll
Now: click lithium, then scroll down to cr2016 and hit apply filters, click the part number, put in the quantity and hit add to order. That should do it. It's a pita, but hey it will save you some money!
ScottL4619
Columbus, OH
I got my 5701 installed tonight. They charged me $140 for the install, and I paid $35 for the XK01 module, bringing the total to $389. This thing is definitely pretty sweet. As it turns out, they actually sent me a 2 way and a 1 way remote, but the 2 way remote said "1 way" on the back. It has all of the LEDs on it, so it's definitely the 2 way, just incorrectly labeled.
This really isn't that exciting, but I'm impressed that the system can tell me the current interior temperature range of the car on the remote...
DenaliAK
Colder than you
Alaska
Yeah, that's a pretty cool feature unless you live where I do. It only tells you if it's below 30 or something, which pretty much describes six months of the year here and isn't real helpful if it's -30....lol.
92__silverado
I see this is now $88.27 with TINA for a code.
After a few months with this would anyone have gone a different route? I see them New for about 100$ more. Would anyone go with another model, or have any complaints about this one?
I ask because i called the local "authorized viper installer" and he said they don't sell the model, and they will not install a system unless you buy from them. He said they use to sell the 5701 but said they had problems with the remotes losing their programming.
Good insight or an installer to stay away from?
Winter is setting in and I think this would be a great thing to add to my hoe.
DenaliAK
Colder than you
Alaska
I haven't had any issues with mine, other than going through batteries fast.
Note on batteries: DO NOT buy them at a department store or whatever where they've been sitting. They are nearly dead when you install them. It's worth the effort to get them from a battery-specific store. There's a link above for one, I use batteryjunction.com for most of my batteries. I'm not plugging any one store, just get good batteries. It makes the difference between them lasting a week or 6 months. I got one from the local all-in-one department store, a Duracell even, and as soon as I installed it the remote did the low battery warnings. That's annoying.
Riff Raff
Arlington,Tx
hmmmm thats nice to know,i put batteries in my two-way and it went dead in less than a week,so i've been using the one-way remote since
DenaliAK
Colder than you
Alaska
I've had the current battery in my 2-way for like 4 months now. The one before that came dead and it literally only worked for a day.
92__silverado
Did most of you have your system installed by an authorized shop or take a stab at it yourself?
jomulk56
Resident Lurker
IN
I had mine installed professionally. A few tips I can provide. Do your homework on installers and who supports the DEI brands. The installer I chose was 1 of 2 in town that deal with Viper, and they did a horrible job. The alarm would drain the battery in less than 2 days and it didn't work right. Their answer was well you provided the system, so it was bad, and we'll charge you another $600 for a new system and install. So, I now have a Skytech alarm and couldn't be happier. The whole system and install was less than $400.
puckhead
CO
I checked websites and found a place that sells and installs them. Figure if they sell em and have been around for a while they should be alright. Get mine put in Friday. Ill let you guys know how it goes
---------- Post added at 10:18 PM ---------- Previous post was at 10:18 PM ----------
Good to know about the batteries too
92__silverado
A lot of places around here (small town) won't deal with you if you don't buy from them. One shop sells Avital stuff, which he said was made by DEI. If i can't find a better solution, I may have to go that route.
ScottL4619
Columbus, OH
Bringing back an old thread...just noticed a problem.
I park my truck in the garage usually between 6pm and 8pm and then leave in the morning between 8am and 9am, so it sits there for roughly 14 or so hours max. I just noticed that in the morning, if I go out in the garage before unlocking or remote starting, the blue LED on the receiver attached to the windshield is no longer blinking. Everything still seems to function correctly (lock, unlock, start). And, while this doesn't seem like an issue in the garage, I would like the light to be flashing if I parked at someone else's house overnight as a deterrent. I have not yet tested to see if the alarm will sound, as I will need to plan ahead and leave a window down so I can unlock and open a door after arming the night before. I found in the manual that the flashing will be reduced after 24 hours, but it isn't sitting that long and it's not just reduced...it's off completely.
Anyone else having this issue?
ASG-MikeS
