Puddle light on power mirrors..
bahollis
Lead Foot
TEXAS
How do you set the lights under the power mirrors to come on? Or do they come on automatically when you're driving? I've never noticed one way or another, and I'm in my shop right now trying to trouble shoot the problem I'm having with my LED interior swap. I just want to see them light up so I can be sure the system is working.
ALSO, I have checked every damn LED bulb in my interior, and they are all seated. I still have to yank one of the LED vanity bulbs and reseat the old "fuse" style OEM bulb in that vacant socket to get the interior LEDs to come on full strength. I can then remove that OEM bulb, and put in the LED vanity bulb in and they work fine. After the vehicle sits turned off for a few minutes however, it has to be reset like I said before.
Second question, is there a relay fuse for all the interior lighting?
Thanks
BH
01TX_Tahoe
Semper Fi
Pasadena, TX
mine come on when i open the door. other than that not sure unless you hard wire them a switch or something.
Thumper8302
OKC, OK
make sure ur dome override switch hasnt been touched.. happens quite often...
bahollis
bahollis
Lead Foot
TEXAS
There has to be a relay dead or something... I just don't know where the hell it is.
Could ANYONE with electrical experience wrap their brain around this one and help me out? I checked all the bulbs, and they are good.
The scenario as it sits right now is this...
The front map lights work when all the overhead domes come on, but once I'm in the cab (and they dim to off) the buttons on the front map lights won't turn them on. Open the door, and they come on. Obviously the bulbs work.
The map lights in the 2nd and 3rd row don't work at all. Press the buttons and there's nada.
Is there a relay or a fuse that is dedicated solely to the map lights?
Thanks in advance.
BH
Rivieraracing
I can't think of one right off hand but I do recommend going through ALL of the fuses one by one and see if any are burnt out!
Rivieraracing
I feel your pain but it has solved a few problems on my denali, sometimes circuits are piggy backed together but not in the label of the fuse! Good luck and keep us informed!
bahollis
bahollis
Lead Foot
TEXAS
Found it.. TBC 2C it's in the dash panel fuse block. 15A fuse. I still don't know why the heck it blew, but it did.
I actually found the answer on a Diesel truck forum. Googled it.
Now.... I need to figure out if my puddle lamps on the power mirrors even work before I order LEDs. When exactly should they come on? Are they controllable, meaning can they be disabled? If so, how?
Thanks
Rivieraracing
I haven't even noticed if they work during the day but whenever I open my doors at night or also when I turn off my alarm they turn on. Also I think I can somewhat control them through the driver information center in the truck.
Glad you found the fuse, like I said it sucks that sometimes we would need to check every fuse you have for a problem!!
bahollis
bahollis
Lead Foot
TEXAS
I hate this shit. Now that I have the fuse replaced, it's back to the same problem. If I put all the LEDs in and let the vehicle sit idle for a few minutes I have an issue.
All of the lights that were on that 15A fuse (vanity mirrors, switched front Maps, 2nd Row Maps, and 3rd row Maps) come on at about 25% brightness. They are not full strength. I know this, because when I remove a bulb (any bulb) and replace them with the old OEM fuse style bulb they all come on full strength. I can then remove that OEM bulb and put in the final LED, and they stay on full strength until I let it sit idle with them off for a few minutes.
So it's as if any combination of LEDs and OEM bulbs is either not drawing enough current to come on fully. Those LEDs can't have the polarity reversed on them, so they only work one way. When I put in an OEM bulb that can be reversed.. it completes some circuit and they come on. AND, to make it really F&%King stupid... if I leave the OEM bulb in, and let it sit idle, I have to remove the MF'ing OEM bulb and put it right back in for them to come on fully.
The only thing I have yet to do is rip out all the LEDs, and replace the OEMs to see if I still have the current issue.
WHAT THE f^&k?
As trivial as this all sounds to anyone that's putting $3k rims on their hoe, this is really pissing me off. I spent $60 on LEDs and I have inherited a freaking gremlin along with them.
http://www.facebook.com/v/1633885654756
BH
Rivieraracing
That does suck for sure!! I'd start over and put all the OEM bulbs back in and see if you do have the same problem!! Let me know the result of putting the OEM's back in, and if it solves the problem and works right, one by one start put the LED's back in and check each one to see if they work correctly before putting the next one in!
I don't have the slightest idea why your truck has that problem with the LED's, I'll keep racking my brain for a solution!
bahollis
bahollis
Lead Foot
TEXAS
Does anyone here know if the dome dimmer switch runs off a relay? I read somewhere that the switch might be having an issue with the power that the LEDs draw. I wonder if the dimmer portion is a relay?
For now, I have switched all my LEDs back to the OEM bulbs, and I'm letting it sit and reset. I'll go out later and see if they are fully illuminated. If so, I guess it's the LEDs... if not, I'm guessing there's a hidden relay or a short somewhere.
In that video I posted, when I replaced the LED on the vanity with the OEM bulb I can hear a distinct "click" come from behind the lower dash area by the steering column.
It sounds like a relay, but I have no idea where to look other than the fuse panels in the cab.
Any ideas?
BH
bahollis
bahollis
Lead Foot
TEXAS
Still don't know WTF the deal is with my Puddle lights. I have yet to see them come on. I do have an aftermarket alarm, so I'm guessing that's the culprit.
Now onto the interior LEDs. I took them all out and replaced them with the OEM bulbs. There is no loss of current, and they all come on as bright as they go.
Soooo.... first I pulled the front map lights and put in my LEDs. I let the truck sit a while, and turned them all on... and the LEDs are dim. Open the vanity mirror that has the OEM bulbs installed (I heard that little "click" again from down by the steering column) and the map lights come on full strength again.
I have pretty much narrowed it down to the vanity lamps having something to do with the current flow to all the map lights. If I replace the vanity bulbs with my LEDs, I have to remove one of them and plug in an OEM blub to get them to come on fully. I can only assume this has to do with the LEDs not being pole-reversible. I suppose I could be wrong, but I can't think of anything else it could be. If the High Power LEDs draw more current than the OEMs then why does it need a low power OEM bulb for them to light up?
So now I have all my interior lights changed to LEDs, and when I want them on fully I just quickly open and close the vanity mirrors (which are still the OEM bulbs)
BH
ludvball
If i remember correctly, when you program the memory of each driver (seat position, mirrors, pedal height....) there is a setting for the puddle lights.
bahollis
bahollis
Lead Foot
TEXAS
Puddle Lights
How so? I only have the ability to program my driver seat, and I adjust the angle, ride height, fwd-back & foot pedal depth, and then the angle of mirrors... then press "1" or "2" to set on that button. I don't recall a light option though.
BH
ludvball
BH
It is part of the Driver Information Center (DIC). This is controlled with the 4 buttons on the steering wheel. The button you would use is the top one on the right. It is the perimeter lighting function. When turned on, the perimeter lights, headlamps and back up lamps all light up for 40 seconds.
I am not sure if this is available on all vehicles. I have an 03 Denali.
bahollis
bahollis
Lead Foot
TEXAS
Yeah, I have mine on... but to my knowledge no puddle lights. It was my understanding that they only lit up when activated by the key fob, when unlocking the doors from the outside. Now, I have an aftermarket alarm so it may not be controlling it... just the door locks & alarm sensors.
Dunno.
It drives great though!
BH
ludvball
Dunno.
BH
Sounds like it might be the aftermarket alarm. here is what I pulled out the owners manual:
Perimeter Lighting
Press the personalization button until PERIMETER
LIGHTING appears in the display. To select your
personalization for perimeter lighting, press the select
button while PERIMETER LIGHTING is displayed on the
DIC. Pressing the select button will scroll through the
following choices:
PERIMETER LIGHTING ON (default): The headlamps
and back-up lamps will come on for 40 seconds, if it
is dark enough outside, when you unlock the vehicle
with the remote keyless entry transmitter.
PERIMETER LIGHTING OFF: The perimeter lights will
not come on when you unlock the vehicle with the
Choose one of the two options and press the
personalization button while it is displayed on the
DIC to select it and move on to the next feature.
Although, I thought my lights came on when I exit the vehicle. I will check tonight.
bahollis
bahollis
Lead Foot
TEXAS
I might tru locking and unlocking the door with the key tonight, just to see if it comes on then.
the only reason I even give a crap about them is because I'm having the issue with the interior lights and my LED swap.
BH
bahollis
bahollis
Lead Foot
TEXAS
I saw the puddle light on the passenger side come on today. I'm guessing the driver side worked too.
Now we can all sleep at night.
BH
Candielaine
