4.10s installed but some problems
renaldo99
i got the 4.10s installed, it seems to drive fine and it chirps 2nd gear but when i let off the gas at about 50mph and it feels like something is gonna break in the trans or rear end, like it down shifts really bad an the whole truck shakes... is this cause it hasnt been tuned for the new gears?
redemn93
Jupiter, Fl
id take it back to the installer and tell him whats going on. let him drive it with you in the truck to show him.
Ski
Alabama
^^ was thinkin da same thing.... Wish I could feel da power lol
renaldo99
renaldo99
I took it to a new tuner and he was saying the converter is locking up thats why its acting weird, so i gotta get it retuned and the stall is too high for my setup but he can work with it... Hes been doing this for over 20years so i trust him
candyman74
arnold, mo
so did you do the front and rear? and what all did they replace as far as the just the gears or anything else, and what it cost you?
renaldo99
renaldo99
keep us informed.
So like how the 4.10's pull now? :)
well i just ran my jet chip programmer 4 on my pcm and changed the tire size and the gear ratio but nothing else. My truck seems to drive fine now so idk if i should get it retuned lol
and i havent really got on it yet but it feels faster..
---------- Post added at 05:30 PM ---------- Previous post was at 05:27 PM ----------
I Got F&R 4.10 ring and pinion with bearing kits for F&R for $590
KrautBurner
Bremerton, Wa
how much was the install?
I'd really like to re-gear mine,
but not sure about the investment cost
thehoe92
fo sho
The916
good is you'll launch off the line quicker with taller tire size
bad is if you do a lot of highway driving your RPM's will be higher
I have 4.56's with 305/35/24 tires and I actually increased MPG even though going 65 its at 2300 RPM
if you can do the install yourself and you don't have your entire diff blown up its fairly cheap to do
renaldo99
renaldo99
Got everything fixed and retuned.. Havent really punched it on 2wd but it seems faster but on 4wd its a effin beast! I was testing it out and just punched it at a deadstop and all 4 wheels burned out then it grips after but damn lol
hoe
Thats true, cause the engine can be in the sweat spot at a higher rpm. You are actually the 3rd person who has reported a increase in mpg all around. Im planing some 4.30s with a trutrac for my 2wd with the vmax.
---------- Post added at 12:25 AM ---------- Previous post was at 12:23 AM ----------
him moving from 3.42s to 4.10s must feel huge. but from 3.73s to 4.10s aint much difference. 4.56s is a tad steep in my book. I would seek some 4.30s as the perfect gear for our truck. Wheels 20-26" will work all around with that gear.
thehoe92
fo sho
The916
damn renaldo you are making me want to do my front diff now!!
I still need to get mine retuned I'm just too lazy to send it in to blackbear
MUDHOE
remember that he has got a built supercharged motor w/ alot more power than yours im betting a somewhat stock motor wont roast all 4s
hoe
LOL, he is prob making a extra 90hp too, to the wheels too.
MUDHOE
just curious how much do you have into your motor and tranny wise? i might be able to put alot of money into my hoe and am thinking supercharged or 6.0 swap idk yet
renaldo99
renaldo99
just curious how much do you have into your motor and tranny wise? i might be able to put alot of money into my hoe and am thinking supercharged or 6.0 swap idk yet[/QUOTE
Ive spent about 11K on my 5.3L motor and about 3K on the trans/gears..
If its between a s/c and a 6.0 swap i'd just do the s/c
ZaZaZazzels
