Which 2" or 3" rear spring to level an 03 2wd Tahoe?
viperbluelx
I put 22's on my wife's 03 2wd 5.3 Tahoe and now it's more obvious how the rear sits high. I don't want to do anything at all to the front I just want it to sit level. Do I need a 2" or 3" rear drop spring and which brand is recommended that will work with the stock shocks? Thanks!
BlueTahoe2001
Charlotte, NC
3" Is going to put you closer than the 2" will. However, if the spring settles over time you might be sitting lowert than 3" with a 3" spring. So personally I would reccomend a 2" spring.
As far as brand, look into Belltech, MG's, and some others that I can't seem to remeber.
V
viperbluelx
Thanks, I found the Eibach Pro-kit 2" drop for $159 at Autozone with free shipping so I went that route.
V
viperbluelx
I certainly hope these are going to settle. My Eibach Pro-kit 2" lowering springs dropped the rear 1/2". :(
NORCAL SS
SUV SUSPENSION GURU
VIPER do yourself a favor pull the shocks off the rear axle just to see takes 5 minutes if the rear end comes down more. I used to sell eibach never again.
fro 2 inch drop I use the djm springs and for 3-4 i use the belltech. anything else you have questions on just hollar [email protected] or call 24/7 415 519 2432 im allways around to help
V
viperbluelx
I can try pulling the shocks, but I don't have the autoride or anything. These Eibach's were the exact same height as my stock springs, which is odd, although they are progressive rate.
NORCAL SS
SUV SUSPENSION GURU
doesnt hurt to try. The 2 inch eibach springs allways gave less drop then advertised. You might have to switch it up.
NORCAL SS
SUV SUSPENSION GURU
most likley they will tell you its used wont take it back.
trust me on this go with the belltech 3-4 inch rear adjustable kit with the shock extenders my customers are very happy with the ride.
V
viperbluelx
I spend 3-5K a month there, they will take them back :)
worleytrev93
