Whats next????
renaldo99
I still want more power but i dont know what else i can do, ive done almost everything lol and i dont wanna go with nos something else to get more power..
let me know tyf.com
hoe
Get a Supercharger camshaft, retune. Also, drop to a smaller pulley on the SC. Make more boost with it. Still tired of it? Then move everything over to a 6.0 or a 6.7L (408)
renaldo99
renaldo99
idk if u saw my signature but i already did all of that minus the the 6.0l/6.7l
KrautBurner
Bremerton, Wa
LS6 heads?
there are much better heads out there than LS6 heads (especially for supercharged)
4.11:1 gears
don't be a *****,
give her a little spray ;)
if you're considering going to a 6.0/6.7 etc
I'd say go with an "LSX forged block" and build from there.
HMFDZ28
Hunt Sta, NY
Gears, Pulley, Forge the rotating assembly, build a larger cube motor.
Personally I would get a nice set of heads. Just be prepared to see the accual boost number drop due to the decrease in head restriction. So a nice set of heads, a pulley, and a retune.
renaldo99
renaldo99
How much boost are you seeing? What are your current dyno numbers?
7psi boost and im pushing 420hp and 392trq to the wheel
picture.php
renaldo99
renaldo99
i was thinking on doing that... but if i dont put new heads and just do a new pulley for more boost will i be save with the motor?
JennaBear
Resident Ninja
San Diego, CA
I was running 11psi on my 5.3L, you should be just fine, these motors are pretty stout. It is the drivetrain that is the issue on these vehicles.
renaldo99
renaldo99
Pulley down, you have more power to tap.
will it be safe with 70k miles reason being is the place i took it to that installed everything said i have to change a few things to the motor so i can up the boost so idk
JennaBear
Resident Ninja
San Diego, CA
I would definitely ask for specifics, I know plenty of people running high boost on stock engines.
renaldo99
renaldo99
I would definitely ask for specifics, I know plenty of people running high boost on stock engines.[/QUO
they changed a few things when i did the camshaft like the pushrods and the springs so idk what else they can do
johnsonwillie199
