hitch cover keeps coming off!!??
02Lightning
Anyone having any problem with the hitch cover coming off? It will come unhooked at the top and it will be hanging from the bottom 1/4 turn screws about once a week. Wonder if the dealer replaces it, will that solve the problem.
m332is
I just took mine off and it is sitting in the garage.
Vince
Punisher66
Albany, NY
I saw one laying at the exit of the car wash the other day. Just got blown off by the dyers with out the owner even knowing. I would just take it off, eventually it will get lost.
Poncherello
Mine's been fine but it's only been a month :party33:
stevek
Dallas, TX
I've had no problems with mine... worst comes to worst, just hot glue it in there... easy to take off if needed
catnhat
Milwaukee, WI
Velcro.
1. Put a piece about 2" long on left and right side above the reciever leaving the adhseive side open towards the cover.
2. Install the cover,
3. Press firmly to adhere to cover in velcro locations.
4. Drive away "secured"
Been working for 2.5 years for me!
Erebos
Velcro.
You got any pics on yours? I just got the unit on mine and boy, that one page of instruction that came was it was a piece of crap. I think that they have slightly change the rear bumper from the inside on the 2010 because it seems like it already has all the holes where you can just slide the cover over without drilling or punching any additional hole.
Mr. B
Rockford, IL
I lost one of mine. Got another one and drilled a hole by each 1/4 turn and put a nut and bolt through it. Good thing I did, I'll had the top tabs come out several times since putting the new one on. Won't lose it with the bolts on there.
I'm going to try the velcro trick though, to help keep the tabs from coming out.
sparky5309
Maryland
This happened to mine too. What happens is the plastic tabs on the cover become worn (rounded off), and they don't hold it into the bumper anymore. Velcro sounds like a good fix - i replaced mine. had to be painted - cost a butt load!
vsaravia
