Newest update released. Cabin cam/signal cam
scotflyer
So...If it records activity around the vehicle, can I use a thumb drive in the console and store that activity ? Would the thumb drive need to be formatted before using ? It would act like a dashcam .....
2025 Yukon Denali.
Thanks.
RST Dana
OH
2025 Yukon Denali.
Thanks.
USB minimum 32 GB formatted to FAT32 before inserting into your ride
ReaperHWK
ReaperHWK
2025 Yukon Denali.
Thanks.
Yes dash cam and also records when alarm activates.
ReaperHWK
ReaperHWK
I have a 2026 HC. Mine doesn't display. Is this active only when towing? Or is there some hidden activation needed? Thanks.
lost1wing
West Georgia
The USB ports in my 2025 are an either or. I can't use one for music and the other to record at the same time.
You can play your music via bluetooth from your phone. This leaves your usb port available for a thumb drive. Are you connecting your phone to the truck with a cable? Or is your music on a thumb drive?
CrackerJack135
