2026 Tahoe-auto braking settings
Almanor
Got a 2026 about a month ago. The driver options for the alarm and auto braking will not stay turned off. Every time the car is turned off they all reset to have both the alarm and auto braking for everything. The dealer spent a day uploading and updating the software and nothing. They say they can’t figure out why it keeps turning all that stuff black on.
Anybody got any ideas or dealt with this.
Thanks for any comments…
2024 White Tahoe
Does the vehicle owner’s manual (available online) state that the auto braking system can be turned off and remain off?
What alarm are you referring to?
No ideas on how to fix but I’d return to the dealer and insist the vehicle be repaired.
Keep meticulous records as you may have to invoke your state’s vehicle lemon law.
ReaperHWK
I have a 2026. I keep those features on but I’ll disable them next drive and see if it stays off.
It may be a software setting where if you disable it it’s only disabled for that drive cycle. Kind of like the auto start/stop. I am guessing that’s the case and it’s working as intended.
A
Almanor
The dealer says that it should stay off once I go in and set it to no alarm or activation. They are saying that the other Tahoes it stays off and only reset to on if they go in and change the settings.
It seems weird that they have the options active and then they don’t stay as manually set.
I thought I had it all turned off and it reset without my knowledge and almost wrecked me out on a sharp turn when it thought an oncoming vehicle was going to head on. Seems dangerous to me.
Marky Dissod
Long ago, owned a '94 Fleetwood LT1. Unlike Caprice/RoadMaster, it came with Acceleration Slip Regulation, aka Traction Control.
(Side benefit of Traction Control is 4Channel ABS. Caprice/RoadMaster had 3Channel ABS; lacking Traction Control, 3Channel ABS was cheaper for GM then.) ANYWAY
Even back in the 90s, had to open the glovebox to disable Traction Control each & every time I restarted the engine.
Collective efforts of the ImpalaSS Forum over nearly 2 decades never found how to disable ASR upon startup by default.
GM's beancounters & legal depts seem to 'agree' that GM's arse is better covered by forcing the driver to disable these 'safety features' upon each startup.
You get what you pay extra for, I guess.
For the record I think that the driver(s) should have the option of temporarily OR permanently disabling any combination of 'safety features' as they see fit,
until they decide to reenable any combination as they see fit.
But it's easy to imagine that GM fears a scenario where a driver's 'failure' to enable a 'safety feature' results in them suing after a calamitous collision,
"The default should be always on til the driver intentionally countermands the safety feature!"
I happen to know that Porsche allows the driver the option of disabling the ABS; however,
ABS will TEMPORARILY re-enable so long as the (adjustable) Stability Control happens to be in use/effect, immediately after which the ABS re-disables.
ReaperHWK
I thought the auto braking was only for reverse???? Mine has activated once (reverse) and it actually saved me from a collision.
I’ll sometimes get the red line on the HUD if it thinks I’m going to hit something but it never auto brakes in forward gears.
Btw on the way to work today o turned off the auto braking. I’ll let you know if it’s still disabled when I go home.
QwikKotaTx
Our window sticker has the items below before any options so I don't believe it's just in revere.
ENHANCED AUTOMATIC
EMERGENCY BRAKING
FRONT PEDESTRIAN AND
BICYCLIST BRAKING
ReaperHWK
ENHANCED AUTOMATIC
EMERGENCY BRAKING
BICYCLIST BRAKING
I see. I guess I never almost hit a pedestrian yet!
TexasTaz
