Useless Information
mountie
Better air flow will boost a lawnmower.
I suppose, having a “high-performance” air intake is good if…….
You push your gas peddle to the floor….. But gas savings isn’t an issue then.
My Airaid is helpful allowing my hands to reach around the front of engine, and also a common sense design instead of the ‘funky’ design of the OEM / noise reducing intake.
Marky Dissod
I suppose, having a “high-performance” air intake is good if ... You push your gas pedal to the floor ...
Surprising gains from sealing up an electric leaf blower to the intake. Wire it up so it adds 'boost' over 75%-83% TPS,
and recharges whenever under 66%-74% TPS. Better value than a 'cold air intake' in terms of performance gain.
homesick
The Best Me I Can Be
Navy Air Force
Huh, my memory was that a better flowing airbox did nothing until the engine was making over 350-375 horsepower. Then again, he tests on an engine dyno with headers and his baseline junkyard engines are making about 375 horsepower at the flywheel if I remember right.
I was going to get a Volant for my 6.2 pickup but never got around to it.
I've seen that guy a few times on 'Engine Masters'. Never seen his YT stuff. FWIW, he struck me as a clown.
joe
homesick
Navy Air Force
A big reason for the noise reduction is federal noise regs. I'd guess it's also a big driver of the 'funky' OEM design.
joe
homesick
Navy Air Force
The laws of physics don't get suspended just because you want to disagree.
Neither do the laws of diminishing returns, big fella; nor the influences of which points on the ruler you're measuring to and from.
And I didn't disagree. I just pointed out that there are shades/variables involved.
joe
Dirty looks
joe
The guy you're calling a clown likely has more real world knowledge of LS performance than anyone on the planet. Real numbers, not mythology and wives tales.
Dirty looks
joe
Pray tell, share a shade or variable where better air flow doesn't increase performance.
homesick
Navy Air Force
You love your opinions being absolutes, don't you?
joe
homesick
Navy Air Force
OK, which rule? Applies to what? Lord forbid I misread one of your proclamations again.
joe
mudrunnerz
