Rear Heater Core
tekfire07
Dose anyone know the size of this fitting going to the rear heater core? I want to cut this one off at the crimp. Then splice in a new 5/8 aftermarket connector. Thanks in advance for any help.
rdezs
You can carefully cut it at the crimp, or replace it. Dorman has a 3/4 inch quick connect elbow that goes to 5/8 hose barb. Drop your spare tire and look up. You'll see the two half inch aluminum pipes, the hoses are cripped to the end of those pipes. It's easier to use a small pipe cutter and cut the pipes, then use a half inch compression fitting adapted to a hose barb.
Here's the parts I used, along with 5/8 silicone heater hose.
And then there's the old ones that were all rotted
Here's where I cut the aluminum pipes...
Not very user friendly to get in there and carefully cut the crimp off, which is why I went with relocating the connection for easy access later on. You can see where the original crimps were
Everything's available on Amazon. I used the half inch compression to 8AN male fitting. Then an 8AN female to a 5/8 hose barb. I prefer the oetiker crimp connections, but of course you can use your choice of hose clamps.
tekfire07
tekfire07
Thanks that is a huge help.
tekfire07
tekfire07
Do you know how many feet of heater hose is needed?
rdezs
I think I bought 6 ft total. Had maybe a foot and a half extra.
rdezs
The inexpensive ones that come with a set of crimp rings work just fine. Just as well as my $40 crimper for PEX tubing clamps. These days you can buy a set of the crimp rings that come with a crimp tool for the price of 10 screw clamps.
rdezs
And by the way, don't go cheap on the heater hose. Silicone is very heat resistant, which is why I went that way. You've got the exhaust nearby, plus the right rear tire throwing all kinds of crap up.... And if you lose one of those hoses on the highway, you will lose all your coolant rather quick.
opfor2
Riverside County, CA
How well do the "Oetiker crimp connections" work?
KC 2013 Tahoe
Chandler, Arizona
Very nice on the crimp fittings. You can make the repair even better by using the newer Dorman #800-419 Aluminum fittings... much better than plastic:
www.oreillyauto.com/detail/c/dorman-oe-solutions/dorman-oe-solutions-heater-connector/doe0/800419hp
Mbarindelli
