builds4christ
- Joined
- May 14, 2024
- Posts
- 78
- Reaction score
- 52
Haha no worries, I almost imploded my engine with vacuum lol!Oops, the way I kept imagining it, there was no clean air supply side.
I'm a moron, don't listen to me..
Hey DK.What is your vacuum at idle, using a physical gauge, also is the needle steady?
Have you done a leakdown test of the injectors? Verified fuel pressure?
Are the O2 sensors AC Delco or aftermarket?
Miles on plugs, are they AC Delco?
Just a few questions to help try to diagnose.
What should the vacuum be at idle?
Hey DK, sorry for the delay. I still have to check vacuum at idle. Been a inundated with other projects and had to put this one down.I don't know what these are supposed to pull, but I would assume 18-21 inHg.
Can you elaborate more on the history....how long have you owned it, and after you purchased it, what have you done to it and what if any problems were present at time of purchase and did the problems start before or after any service you performed.
Was it acting up when you bought it?
We definitely need to see what the PCM is seeing in regards to alcohol content. Could have alot of E85 in it and maybe it's not a flex vehicle.
I inspected the interface to the heads and I didn't find any soot anywhere. I do have a leak at the resonator a little downstream of the upstream sensors.Are you positive your headers are sealed to the block and exhaust and not drawing air into the system throwing off your sensors? Smoke checking the exhaust can find leaks. Blowing air into the exhaust with a shop vac while searching the pipes and connections with soapy water also works. I fixed a 2010 GMC Acadia using the shop vac trick to find the leak. It does not take much air intake to mess up the readings.
No worries, I know what you mean.Hey DK, sorry for the delay. I still have to check vacuum at idle. Been a inundated with other projects and had to put this one down.
It runs well enough for a while iluntil it toasts the 02s. The codes pop and about 24 hours later it really begins running badly. Swap in new 02s, runs well again. Annoying right?
I unplugged the purge valve so that it wouldn't open.I'm kind of stuck on this statement:
"7) purge valve delete (unplugged purge valve and capped intake port, but left everything else running in evap system)"
A couple points here, keep in mind you're in a bit of uncharted Territory....
1. So you capped off the intake port, but left the purge valve open? So you have fuel vapor pouring out over your hot engine while you're driving down the road?
2. I'm assuming as the day warms up the fuel in the tank expands increasing the pressure. There's a sensor in there that communicates with the ECM.... Not sure what it does when the fuel tank gets over pressurized. You may have to remove the vent valve solenoid so that vent valve can operate freely both ways. Just a thought.
3. I would assume an overpressurized fuel tank will make it easier for the fuel pump to pump, curious if you will see higher than normal fuel pressure as things warm up.
Just with these unknowns, I see a lot of potential for drivability issues. No idea how it will all interplay together with your configuration. Just food for thought.
