Replaced afm lifters
Mlstammerjr
Hey all. So I had a collapsed lifter on my 09 Yukon. We replaced all of the lifters yesterday (8 regular and 8 AFM) after getting it all put back together, it started right up and ran fine until the engine got hot, then the oil pressure plummeted and you could feel the engine starving for oil. No check engine lights, oil is full on the dipstick. What could be causing this and what can I check to diagnose this.
Google ai (I know it’s not always reliable, but that’s why I’m here) says that the valley gasket is either bad or possibly not torqued to spec. We did replace the gasket but it’s a cheap gasket as it was all I could find in stock. My dad put the cover back on I honestly don’t know if he torqued it down to spec or not. I know he torqued the heads to spec and the exhaust manifold. I’m waiting on him to reply on whether or not he torqued that right.
But anyways , is that likely my issue or something else? Where should I start with diagnosing this?
randeez
south florida
how was oil pressure before swapping them all?
was there a failure or just trying to be proactive?
did you disassemble the entire vlom (afm actuators) from the underside of the valley cover? the gasket does come with the pedestal gaskets but kinda hard to mess up. and the perimeter gasket doesnt do anything for oil pressure
and welcome to tyf
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
You are already receiving clarifying questions from the knowledgeable folks on this Forum.
When you say that the oil pressure plummeted, what was the psi reading from your oil pressure gauge at that point?
What was the oil pressure reading before your performed this work, when cold and at hot idle.
M
Mlstammerjr
and welcome to tyf
The oil pressure was fine before mostly, it had intermittent issues with the oil pressure sensor, but no actual pressure issues, just the sensor going out. There was a lifter that had collapsed that was why we changed them. But it’s got an oil leak and I think it ran low on oil a few times, that’s why the lifter collapsed. It was misfiring before and you could hear it chattering, when we got it all back together the misfire was gone and no chattering. The oil pressure was fine until the engine heated up.we didn’t take apart the vlom at all
Thank you
tooleyondeck
Northwest FL
Pick up tube o-ring, oil sending unit, oil pump itself, there are a few usual suspects but it sounds like you didn't touch the timing cover? Possibly did not delete the AFM system?
Could you clarify whether you retained or deleted the AFM system?
M
Mlstammerjr
K
I did not touch the timing cover and the afm system was still retained.
rdezs
Not too many people here repair the AFM system. Viewed as a ticking time bomb, moving forward with a delete after an AFM lifter collapse is the norm.
I do recall that GM says that anytime the VLOM is removed, it should be replaced.
Considering nothing else was touched, the most likely culprit is a leak under the VLOM plate. This posting reads like the gasket around the perimeter of the plate was replaced.... I don't think that's a real option. The integral gasket involves some disassembly to replace, also covers the oil towers in the middle of the valley. If you somehow just replace the perimeter, the new gasket will increase the height of the plate slightly.... And the existing seals over the towers won't be compressed enough.
I think a new VLOM plate is necessary, torque down properly. (With new OEM GM oil pressure sending unit with new screen underneath)
If you still have an oil pressure issue after that, then I would pull the pan, replace the pickup tube o-ring and the pressure relief valve mounted inside the oil pan on the driver side. While you're there you can remove the oil pump pressure relief spring and valve, make sure it's clean and not gummed up and sticking.
The best all around fix, however, is simply do the AFM delete for long-term reliability.
Marky Dissod
No one should.
Has been for at least 10 years now, and yet ...
If you somehow just replace the perimeter, the new gasket will increase the height of the plate slightly, and the existing seals over the towers won't be compressed enough.
EXACTLY.
I think a new VLOM plate is necessary, torque down properly. (With new OEM GM oil pressure sending unit with new screen underneath).
Better yet, NOT a Variable Lifter Oil Manifold Assembly; see the above.
If you still have an oil pressure issue after that, then I would pull the pan, replace the pickup tube o-ring,
Older the engine is, the less V4 mode saves fuel, and builds up carbon in the part time cylinders.
Engine reliability and longevity are best served by disabling & deleting Engine Half@$$.
07burban88
this is why i swapped to the 4.8. no AFM and i got the motor for like 300. but yes, delete the afm completely. its also possible the collapsed lifter damaged the cam
K
I would do what @rdezs suggests in Post #7 to replace the VLOM cover and associated gaskets, as that appears to be the most likely the root cause of your issue.
jackal78
