4 Caliper Question and Wheel Check
jgold47
I've been reading about doing the NBS 4 caliper upgrade to my 2018.
Near as I can tell, I need the calipers/pads and rotors for any 2019+ truck/suv
will need a few grade 8 washers to help center the caliper.
This may cause the caliper to hit the wheel however. (anyone know if these wheels clear?)
you might be able to grind down the extrusion on the front of the caliper or you may need to use a spacer
Will I need new brake lines (I think the previous generation needed slightly longer ones)
I will also need new caliper bolts (to the carrier on the hub right?)
Will I need new Banjos?
Anyone done this and regretted it?
Does the change in brake bias hard to manage?
Thanks for the answers - have someone locally selling eveyrthing I need for cheap and I've been watching this for a while to do.
thanks!
Marky Dissod
... been reading about the NBS 4 caliper upgrade to my 2018.
After 27 years, can we stop with the BS, please?
Near as I can tell, I need calipers rotors and pads from any 2019+ (GMTT1xx) truck/suv
Indeed.
I might be able to grind down the extrusion on the front of the caliper or you may need to use a spacer
Here are some helpful links in case you want to grind down the calipers:
That thread also mentions which washers you'd need to use to nudge the caliper so the rotors are centered in the caliper.
I bet it also mentions if those wheels will clear without caliper grinding.
The thread I linked to is VERY long, but it eventually covers almost everything you need to know.
Very strongly doubt it.
Is the change in brake bias hard to manage?
Huh? By which I mean, I've not read any complaints about any brake bias change.
jaxscuby
Jacksonville, FL
I had to use spacers to clear my 22" snowflakes..looking around for +2019 wheels..
I didn't have grin anything of the caliper due to the wheel spacers..
I bought stainless steel braided brake lines..came with new banjo bolts & copper washers
See previous answer
No, braking actually feels better.
I will say due "Hard braking" the nose dive is abit more since the caliper swap.
but during normal braking..feels pretty flat.
enigmaspeed27
