Instrument cluster lights turn off when map light is turned on
I generally do, with the exception of bulbs for the most part. When I reconnected the visor I had the mirror flap closed but you're right, it's still a live circuit at the pigtail.
On the 2105+ they made the whole system go to sleep mode, pretty much everything goes dead to the world, except the horn I think. but if you open the drivers door the (most buss) radio/cluster comes to life and the fuel pump primes. just from opening the drivers door. funny I can open the door and the radio starts playing..... same if I shut it off and lock it the radio might still be playing for a bit..... and it hijacks your phone bluetooth, if you get a phone call and the system is awake it takes over like you were driving, annoying sometimes.
D
dkad260
Last night I started it up to find only the IC lights flickering....along with the 3rd one blown now.
#17 IS LPS.
I will have to recheck the visors. The only thing I have done in the last 3 days was move my LH visor over to block the sun.
D
dkad260
Looks to be the driver's side visor causing the issue, I know @mikez71 mentioned the visor in the beginning, what threw me off was the passenger visor had similiar readings. I moved the visor to the side to block the sun and extended it, that night I noticed the flickering. I replaced the fuse and all was good, my son drove it another day and the following night he said the lights were flickering, I asked him if he extended the visor and he said yes. I have since unpluged the visor and no issues since, I do want to take it apart and see where the likely chafed wire is. The fuse would blow only when the visor was extended, not when just moved to the side.
CRN_25
