donjetman
- Joined
- Oct 22, 2018
- Posts
- 2,004
- Reaction score
- 3,688
filter change every 50k miles or soonerAbout 20k.
Went with the ring on drivers side as suggested, seems to make a good seal, thanks.I agree, use the donut just like the factory did. I know you have the tranny bolted up now but make sure the torque converter spins free inside the bell housing. If it does not your only option is to remove the tranny bolts and back the tranny off to gain room to spin and seat the converter. It is super easy to get it on one or two of the splines inside the tranny while it needs to seat on all three splines. It slips back a little more with each engagement.
When I did my Escalade tranny 3 years back I let the torque converter slip forward off the third spline as I installed the trans. Did not catch that till I had it up and in place. Such a pain to waste time fixing an avoidable mistake. I double and triple check now before mating the tranny with the engine.
Looking forward to hearing about your power increase over the 5.3L. I have only owned one 6.0L, it was in a 2001 Denali and at 320 HP with only a 4 speed tranny that rig was a beast back then. Screamed to 6,000 RPM any time you asked. My only issue with the early 6.0L was morning piston rattle. Never failed, just not what you wanted to hear with every morning start up.
Hmmm you do have me a little concerned but I think I’m al right. I honestly didn’t even try to rotate the TC at that point. After bell housing was fully seated against engine, I tried rotating the engine at the balancer, not the TC. Engine didn’t seem to want to move at all, and then I panicked a bit because I had read about the possibility of damaging the pump. So I immediately backed out the bell housing bolts to check things out. Only at that point did I try to rotate TC, and it turned freely.Nice progress, on the LS engines when installing the manifold connections I have done several. On these the wire harness lays out really nice as you bring the wire loom back into place. No real guesswork involved. The connectors are unique so you won't hook anything up wrong. I do hook up my scan tool after assembly as it will tell me if a sensor is not reading proper. In most cases you just release that sensor wire and re connect it and they start reading proper.
I am concerned, maybe I read your report wrong about the torque converter? I think you said the torque converter would not turn until you loosened the tranny mount bolts?
If that is really the case the torque converter is not on the third spline. IF it is all the way installed on the third spline the torque converter will spin free with the tranny fully torqued in place. You can reach through the inspection hole and turn it freely to align the torque converter mount bolts. ( 3 bolts ). The last thing you do is spin the torque converter till the flywheel bolt holes line up and bolt the torque converter to the flywheel. Working through the starter access hole. I hope i just read your note wrong on this sorry if I am dense.
You are almost ready to fire it up.
Thanks much. Both tuner and I were doing research after I posted this and we both came to same conclusion that BCM is involved.The signal comes from the ECM....but I'm not sure if the BCM is "looking" for the proper signal to keep the DIC message off after starting. (In other words, is the low oil display the default for the BCM, unless it receives the correct info on oil level from the ECM? Which the tuner turned off?)
Just a theory from looking at some schematics ....if I'm correct, the ECM needs to be programmed to send the signal that the oil level is ok. (The sensor switch is normally closed with full oil....if tuning isn't an option, the two connectors need to be bridged. )
I don't think even HP Tuners will modify this far into the BCM tune....might need a different BCM?
Logic says your ECM has the pin outs for the sensor...I would bridge them, and have the tuner reactivate the function so the BCM sees what it expects.....
