lowh07
I wanna see the finger, lol I've lost a few nails before
This was right after removing the wrap yesterday and it looked much better than I thought it would. If it wasn’t bleeding it would’ve been gnarly. Everyone can thank Doubeleive for this!
Glad I didn’t make the workbench any shorter! I removed the casters but left the bolts which protrude just enough so it’s sitting in the bolts and not the box. Also superglued some of those little felt pads to the bolt heads.
This 5-75 is such a good range and the size and 3/8 drive is nice. I really like Icon stuff
I'm still looking for a nice box for my garage. Which one did you get? Is it from HF?
Sir_Hiro
Automotive Mad Scientist
Sir_Hiro
I'm still looking for a nice box for my garage. Which one fid you get? Is it from HF?
Hobo Freight boxes are actually really for the price point.
I really like my Milwaukee Box..It was a bit pricey but when I bought it, it was one of the few with softclose drawers. Which now almost all boxes have that.
SpareParts
North Idaho
Replaced what appeared to be a leaking AC line. Pulled a vacuum to about 28, shut the pump off and a 1/2 hour later the needles had not moved. So i assume i have no leaks now.
Refilled with 4, 12oz cans.
It was 70 ish degrees out and pressures read, low side about 38 and high side about 150. Temps at the vents idling were 58 dropped to 47 holding it about 1200 rpm.
Need to go for a drive and see what it does.
Dirty looks
Installed my Baseline Overland rack this weekend. Along with 3 Renogy ShadowFlux 110 amp solar panels. Still need to cut the hole to install the Probreeze roof vent. Waiting on the mounting brackets for the Rough Country black out 50" curved light bar.
Dirty looks
Roo
Roof vent is in, but not trimmed and wired.
Cutting a hole in the roof for some reason causes anxiety..
Sir_Hiro
I just installed my rear ac delete kit. Brother is on his way with his vacuum pump and jug of 134. Hopefully this works and I can focus on repairing the rear AC in the fall. Since I did like having it.
Dirty looks
I got 4 of the pistons installed and then SMASHED my finger between the engine stand handle and one of the braces… it’s kind of a sketchy design. Broke the nail straight across way far back on my pointer finger so pretty much gonna lose the nail entirely. Almost passed out so I’m gonna call it quits tonight lol
Harbor Freight is having a sale this weekend. 20% off any single item each day for members (10% for non members) so I got a 5-75 lb-ft icon torque wrench and I’m getting a nice size US General toolbox in the morning!
No good deed goes unpunished. Good luck with the finger.
Sir_Hiro
Had the Vacuum on for a good 40 mins with 0 drop so put 1.8lbs in since the rear was deleted. Owners Manual called for 1.6 but the pressures were a little high so we gave it a bit more giggle juice and now have 45° air out the vents.
Will continue to fiddle with getting the rear AC lines off but amazon blockoff plates worked good.
Also since its gonna be 80+ all week I got the fender flare reattached with JB Weld 2 side tape.
kikeap
