2003 Rear Glass Trim - SOLVED
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Noticed some warping of the plastic trim on the rear hatch glass. Both sides in the area of the hinges.
Suggestions other than take a heat gun to it and try to restore the shape?
Left Side:
Right Side:
TX heat taking its toll .
Update:
It’s not just plastic warping…
The right side hinge is also loose.
dps01
dps01
Senior Member
N. TEXAS
Myself, I'd probably look for a good junkyard replacement glass, or upgrade to the later year glass that's a slightly different style. I think it changed in 2005, but maybe mid-model year.
Agree..
Looked at it this AM after the DIC had a rear hatch open message.
The passenger side hinge is loose making it difficult to latch.
Salvage Yard trip…
dps01
dps01
Senior Member
N. TEXAS
Partial to the 2005 Yukon look myself.
Not a fan of the 3rd brake light on the Caddy.
dps01
dps01
Senior Member
N. TEXAS
Left Side:
Right Side:
Update:
Replaced glass from a local salvage yard.
Broken hinges on original glass
Very loose. Wonder if new stronger strut contributed to its demise…. ?
Picked up a DDM while I was there. Will use the electronics of the replacement DDM (if it works) with my original buttons due to fading…
mikez71
Curious if the clips that hold the liftgate on are e-clips? Mine were missing and the liftgate fell on me one day.
I tried harbor freight e-clips, but they seem a little loose.. I have to remember to check the j-yard next time..
I've got 1 e-clip on one of my liftgate hinges, but I don't think that there is one on the other hinge. I'm going to have to check.
dps01
dps01
Senior Member
N. TEXAS
The ones for the glass are definitely e-clips. Lost one of those little ba$****$ when I changed out the glass.
Lost only slightly less often than the clips for the captains chair armrests and 10mm socketsIMG_0050.jpeg
dps01
dps01
Senior Member
N. TEXAS
Checked the lift gate hinges on the Z71.
Sure enough, missing the e-clip on the drivers side.
Will replace that when the one for the glass gets replaced. Maybe use a c-clip instead…
E-clips would be easier to remove once they're installed.
Tupapi
