Tahoe / Suburban / Yukon / CK Interior and Exterior LED Packages ....
HID_Guy
Senior Member
In this thread you will be able to find links to the Interior (Map and Domes) Lighting, Exterior (License Plate, Tag, Turn Signal, Reverse, Back-up, Courtesy) Lighting and other special application LED bulb packages to upgrade and customize your vehicles lighting. For some vehicles you will see that we offer "High Power" Packages which means you get as many High Power SMD LED bulbs that you can utilize for the application given.
If any questions make sure to post or email us at [email protected], always glad to help. Also if you have a suggestion let us know, we are happy to look into it and get you what you need.
** All Forum members use discount code "tyforum" for 15% off your orders and post what you bought on here (we accept all photos of our products installed) **
** Chevy Tahoe LED Bulb Upgrade Packages:
http://www.hidguy.net/index.php?main_page=index&cPath=534_540_173_598_603
** Chevy Suburban LED Bulb Upgrade Packages:
http://www.hidguy.net/index.php?main_page=index&cPath=534_540_173_598_637
** GMC Yukon LED Bulb Upgrade Packages:
http://www.hidguy.net/index.php?main_page=index&cPath=534_540_173_599_633
** Chevy CK Truck LED Bulb Upgrade Packages:
http://www.hidguy.net/index.php?main_page=index&cPath=534_540_173_598_635
Note: Most all packages (such as interior) are available in White, Blue, Green, Red, Violet and Amber ..... If any specific questions let us know, glad to verify.
thehoe92
fo sho
The916
I could spend so much money on your website haha!
do you have any pictures of the violet LED's?
also for the reverse lights could I buy a set of white for the reverse and a set of the red for the brake lights and have it work? are they the same bulb?
is it just plug and play or do I need to add resistors?
HID_Guy
HID_Guy
Senior Member
Haha, good to know.
Well, photos of the colors are going up soon. As for the Reverse and Stop light, yes they are the same bulbs (3157 bulbs). Both of those applications would be just easy swaps and require no resistors because they are not turn signal bulbs.
HID_Guy
HID_Guy
Senior Member
what about 88-99
Those will be up on the website tonight, and for sure the first post will be edited to show the link. We apologize for the delay in some items being added but we have been extremely busy.
Anything you guys need let us know for sure, glad to help.
HID_Guy
HID_Guy
Senior Member
Any other suggestions from you guys for products you might want ?
Remember, we supply anything and everything, just some items are not up on the website yet, but anything you need make sure to let us know on our request thread in the link below.
xBigNoke
When i put the Switchback bulbs into my truck 03, they dont stay on. The white bulb blinks for a second when i unlock the car then turns off. The only part that works is the amber for the turn signal. Will a LED Load resistor fix the problem?
BlueTahoe2001
Charlotte, NC
I am looking for HIDS for my 2001 Tahoe. Looking for kits for both my Lows, and Fogs. Can you provide me with some part numbers for these kits?
HID_Guy
HID_Guy
Senior Member
You might have the bulbs in wrong or the bulbs you have might be bad.
The bulb not functioning should not be a resistance issue, but you can give it a try. You might want to check with who you purchased your Switchback bulbs, hopefully they can help you in getting replacements.
---------- Post added at 01:03 AM ---------- Previous post was at 12:39 AM ----------
Use the link below for the 00-06 Chevy Tahoe Headlight and Fog Light HID kits:
http://www.hidguy.net/index.php?main_page=index&cPath=534_541_543_85_142_440_614
Erebos
Do you have a bi-xenon HID kit for the 2010 Yukon? I need one for my Yukon. Also does your kit comes with the wiring harness? Please send me a link if you have them. Thanks in advance!
HID_Guy
HID_Guy
Senior Member
Yes we do. Use the link below; that is for 2010+ Yukon Models and the Bi-xenon Headlight kit is listed. As for the wiring harness, if you go with out Bi-xenon (Hi and Lo) kit the harnessing is already built in to the system, so no need to purchase anything else for your headlights.
http://www.hidguy.net/index.php?main_page=index&cPath=534_541_543_85_146_446_509
Let me know if anything else, glad to help.
Erebos
Thanks, I've placed an order, can't wait to have this install. Btw, are there any additional discount for our TYF forum user other than the price listed on the site?
HID_Guy
HID_Guy
Senior Member
You save 15% off your order when you use discount code "tyforum".
---------- Post added at 11:24 AM ---------- Previous post was at 11:14 AM ----------
Links to all LED packages are up. Some are being built as I type but they should be all up soon, if not just let us know and we can rush them if your looking to order asap.
HID_Guy
HID_Guy
Senior Member
are the bulbs for the 00-06 tahoe interior direct plug and play??
Yes, all of our LED Bulb Packages are for the brightest bulbs available and direct swaps, we especially have already done the installs and comparisons with other bulbs so no doubt an easy swap, none of those universal kits with pads and wiring.
HID_Guy
HID_Guy
Senior Member
We have the kits for all the models, we have just been swamped with adding vehicle specific ones.
I will make sure we have them up by tonight for the 99+ Tahoes.
---------- Post added at 11:08 AM ---------- Previous post was at 11:06 AM ----------
are any of these interior bulb kits for the 2010 tahoe? All of the kits listed on your website are for older MYs.
We have not done the newer Tahoes just yet, but we have done many of the new Yukons, just not sure if they are the same.
If you take the bulbs out and send us a photo by PM or email to [email protected] we can make sure and put up the kit asap.
Eickybobby5050
