SpareParts
North Idaho
I have read, The 2007 AWD does not use a VSS for speed and uses tire rotation for speed.
I have looked. The TC does not have a VSS and there is a plug where one would go.
The speedo is registering fast by about 8 mph at 40 mph. Using GPS to check accuracy.
SpareParts
North Idaho
EBay pic to show what mine looks like.
mikez71
Interesting, the speed difference is the difference in ratio..
What happened with the PCM Output Calibration change?
(It does say that is used for speedo and ABS calibration...)
And is ECM showing the right speed?
I wonder if you need to change the speed sensor type and speed sensor calibration.. (repTOS or serial..)
Maybe the BCM is providing the speed data to cluster otherwise...
Similar to bypassing revlimit where you need to select 'calibration' instead of 'gmlan'...
SpareParts
North Idaho
ok long story.
I did not realize when i opened VCM Editor it automatically opened the last opened file so i was only editing the last opened file over and over. Changing nothing really.
Running out of ideas i decided to read entire and was going to start fresh.
Once it was done reading i noticed the final drive ratio had the top two rows as 3.42(ecu) and the bottom two as 4.10(tcm)
Edited it all to be 4.10, saved and wrote the file to the TCM.
After it was done i closed the file then reread the TCM. Once it was done i opened it up and the file only showed the two trans GR.
That's when i realized i needed to write both the ecu and tcm.
After writing them both i closed file. Did a read entire and when i opened that all 4 GR lines read 4.10. Nice
Went for a drive. Speedo is more or less correct. It is still about 1 or 2 miles fast but i think now it's just tire diameter problem.
Problem solved, just needs a little fine tuning to be perfect.
homesick
The Best Me I Can Be
Navy Air Force
ok long story.
LOL, what a relief, huh? It's amazing how much easier things are when you figure them out.
joe
SpareParts
North Idaho
Noticed this in HP Tuners. Wonder what signals it to activate 4x4 mode.
I know on GMT800's it is just a wire from either tc or the actuator to the ecm to active it.
Wonder if the GMT900 is the same.
RooTBeeRthe1st
After a few years at this point I think of having no rear wiper or being able to pop the rear glass...I put a new wiper motor in and all is well again...just need to get the plastic interior trim for the hatch from my storage unit now to finish the job. At least the exterior is finished though. Tried re-glueing the plastic piece to the foam on the glass, we'll see if it stays.
LSCALADE
ok long story.
I run 275/65/18 tire which measures something like 32.9" in diameter, the number that I had to enter to adjust speedo was 31.2" and now its spot on accurate to the GPS values. So if you are wanting to adjust the speedo you can either calculate the percentage difference and subtract that from the current tire diameter registered or just enter the 31.2. I was off also by 2mph and I went from 30.5 to 31.2 and that did the trick. Hope this helps.
SpareParts
North Idaho
Something else i have noticed and i can not pinpoint why.
For some reason Cracker now seems to drive extremely smooth after swapping the diff's. Hard to explain.
I did not have any bearing noise before the swap and the old universal joint was good.
Maybe running the same rpm range but with 4.10's the engine is not lugging like before the gear change?
I don't know but it is another +.
lowh07
Just ordered a stage 5 rebuild kit, case saver, pump plate from Jake’s Performance. Should be pretty bulletproof! I was going to just “send it” with the stock unit but I know it would just be a matter of time. Better to do it now. Should have the engine block back from the machine shop any day now. When that’s assembled, I’ll pull the 5.3/4L80E at once and start working on the transmission. Kinda apprehensive about doing it myself, but I think it’ll be fine as long as I’m very thorough and take my time. I’d like to be able to do it and say that I did it, and it’ll also save me a bunch of money.
justinakay79
