HOW TO: Front Differential New Mounts Install on 2008 Denali
West 1
Just finished the install of both new Front Differential Mounts on my 2008 Yukon Denali, AWD, 6.2L with the 6L80 trans now at 147,000 miles.
Took about 3 hours for both sides and one side repair working alone and I am older and slow for sure.
Found the driver side front bushing was worn, may have been the source of my clunk I hope. Still have not test driven since I was overdue for lunch when I finished.
To install these took a bit of work, have not done this job before. Certainly would have been faster if I had done this as advised when I rebuilt the front differential a few months back. I hit all the bolts with some Kroil before starting hoping to help break them loose and it worked pretty well. This is a CA car so pretty much zero rust.
Working alone I had to get creative to hold the bolts from the top inside the engine compartment while loosening them from under the car., Some straps, couple vise grips and long extensions got all 4 bolts out without too much trouble. Would have been about an hour faster if I had a helper to hold the wrenches up top while I loosened them from below for sure.
To gain space to remove the driver side diff mount I removed the Frame support that spans under the front diff so I could lower the diff a bit more. I removed the driver side CV shaft 6 mount bolts so I could gain just a little more drop in that front differential. That was enough. Was able to slip the old unit out and the new one back in.
For me both mounts were removed and installed from the rear side.
The Passenger side has more room and the CV stayed in place although I did have the entire front diff unbolted on driver and pass side for this job.
The last thing to think about is the Vent tube, when you drop the diff down it will unplug itself. Be sure to plug the vent back in once the diff is back up in place.
While down there it was a good chance to look hard at the previous work, replacing the Rear Main Seal and install of the new Luk Torque converter. Alll looked good, no oil dripping so all good. Just hoping the clunk is now gone from the front differential and I can call this truck good to go for a while.
Excellent write-up! I suggest that you add "How to" to your thread title, as this would be very helpful to folks who will need to perform this maintenance item.
West 1
West 1
Done Joe, follow up. After install I found on some accelerations with a downshift I still have a clunk. I had to work at it to make it clunk but a little disappointed to still have the clunk.
Maybe it is just the transmission jumping 2 gears on a downshift. Does not do it every time, most times it is very smooth but once in a while I get the odd clunk on a downshift.
Maybe they did this when brand new also?
It does feel a little tighter with the new mounts installed.
SpareParts
North Idaho
Mine had a clunk. When going around a corner as soon as i gave it gas it would clunk like it did not know what gear to be in.
Changed some transmission settings and it went away after a few days as the transmission relearned.
Maybe that is what yours needs also?
alvocado
Allen
Cincinnati, OH
I changed mine last fall and used a flex head ratchet at 90 degrees to hold the top of the bolts from below while using an impact. My bolts were very corroded so it's recommended to have new fasteners on hand, especially if you live in the salt belt.
builds4christ
Well done sir! I'm about to tackle this Thursday!
CRN_25
