LSCALADE
- Joined
- May 6, 2025
- Posts
- 231
- Reaction score
- 609
For those with HP Tuners Access on the GEN 5 in my case L83 engine the oil pump is a 2 stage similar to what Stellantis has been using on the 3.6L and the 5.7L.
Basically it runs at reduced load thus making between 20-40psi and that is what you see on the gauges shown. Regardless of WOT mine would never go over 45psi.
In HP tuners you can go into the SYSTEM > VARIABLE OIL PUMP > Under Pressure control my cal was set to 7000rpm, the engine never reaches that type of RPMs. After looking at a police PPV Tahoe calibration theirs was set to 3500rpm.
I set mine at 3200rpm and on first log, when you cross 3200 RPM the oil pump goes to high pressure mode and bumps the PSI to about 60. Once you are below 3000rpm it returns to low pressure mode and thus the Hysterisis is set to 200rpm. You can change that to something like 300 if you like but I think the sweet spot is 3000rpm.
I hope this helps anyone who may not have even known that this exists on these engines. This also makes me wonder if the 2021-up engines that have engine problems are caused due to this.
IMPROTANT NOTE! Do this high pressure turn on ONLY if you have DOD disabled. The high pressure may not play well with the collapsable lifters or the solenoids that feed the oil pressure.
