2012 tahoe ssv rear speakers
jon0047
I have driven myself crazy i have a 2012 tahoe ssv i have read the forum am looked up wiring. Cant figure out the rear speakers ready to just cut wires an run new. The rear doors and c pillars. Any direct help would be great. I ran the vin and have a full list on what was deleted and programmed from the factory on this tahoe but still need help!!!
Welcome to the Forum from NH.
More pics of the truck, please, when you get a chance.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in. We've got a lot of GMT900 Tahoe owners in this Forum, so I'm confident that you will receive some replies. Don't cut and run wires yet.
Pttsbrghfan
Gmupfitter.com has some diagrams for the wiring specific to these trucks
jon0047
jon0047
I have the same links ans they are not longer that way in the tahoe if i change the fade and balance on radio it all goes to front an no sound at the rear side so i think it may have been changed up too
What's going on?
Are your right side D-Pillar speaker wires Dark Blue and Light Blue? Are the left side Brown and Yellow?
If so, they tie into the rear door speakers which in turn go to the amplifier.
the uppfitters typically cut the rear speaker wires inside behind the front/rear door pillar, pull that plastic cover off and have look inside there
also if the 2nd row center console hvac/rse control is not connected that will disconnect the rear speakers, there is a way to jumper it to make the rear speakers work
jon0047
jon0047
This is the vin breakdown for my ssv if it helps
jon0047
jon0047
I pulled the radio today an i bypassed the harness for speakers and went right to the harness in the b pillar by the door plug on both rear still no sound fronts work fine. Next i am gonna try another radio
*** If the 2nd row center console hvac/rse control is not connected that will also disconnect the rear speakers, it can be jumpered, I think @89Suburban did his that way
jon0047
jon0047
I went right from the radio wires on back of the head unit to the b pillar to the speaker wires bypassing all harness and still nothing i check the speakers with another radio source not from the tahoe they work the factory radio isnt putting signal to them is what it seems like
1948Buickroadie
