2025 Tahoe Bose 10 speaker add amp/subwoofer
Hawkcrj
So the pin out has changed on the 2025 Tahoe Bose 10 speaker for adding an amp or DSP.
for the non Facebook people here's the post.
Sharing my work and findings if it helps...
2025 Chevy Tahoe RST with factory amplified Bose (10 Speaker system), no visible mics in headliner, no ANC that I could replicate. If I'm correct in saying this the anc plug should be the 3rd plug on the amp and in my case it was empty - no harness.
* according to Travis' post below all the 2025 have anc now: "They all have anc. It's now built into the infotainment system. There is no longer a third plug for it. The manual states, a dealer can turn it off. But after taking the tahoe to 5 dealerships, no one can turn it off".
Equipment installed:
Audiocontrol Lc2i Pro, JL Audio XDM600/1, 2 x 12W0 in Basswedge enclosure (CP212W0V3)
Mounted the amp behind oem bose amp, lc2i next to oem amp, fit nicely and still somewhat accessible through fusebox access door. It's a bit of a pain to remove the rear quarter panel so wanted to make sure I could access/tweak as needed. There's plenty of room there to mount small amps and fabricate brackets if needed as long as you're not dealing with oem sub there or an aftermarket stealthbox.
* definitely need 25ft of power cable if trying to get from battery to left rear / oem amp location. I used every inch of the length and it was perfect from battery to my amp mount. Battery on passenger side, crossed over under plastic shroud by hood release and drilled through firewall directly above hood release cable.
I tapped signal in to the lc2i via rear doors as I had read from other here and on other forums that tapping into front woofers or oe sub still had issues (but I believe they did have anc where I don't appear to) - even still I chose to grab a full range signal and let the lc2i do it's thing.
Wiring colors at oem bose amp slightly different than my application guide and resources so I made some notes:
LF Tweeter - blue/red, blue/brn - 3.5ohm - pins 7+15
RF Tweeter - wht/yel, brn/blk - 3.5ohm - pins 6+14
Center - yel/wht, blue/yel - pins 1+9
LF Mid - blue, brn/blue - 2ohm - pins 3+7
RF Mid - yel, yel/blk - 2ohm - pins 2+6
LR Door - grn, grn/blk - 3.5ohm - pins 3+11
RR Door - wht, blue/blk - 3.5ohm - pins 2+10
LR Surr - wht/grn, brn/wht - 3.3ohm - pins 5+13
RR Surr - vio, gry/wht - 3.3ohm - pins 4+12
Sub (in console) - blue/gry, grn/blk - 1ohm - pins 1+5
Previous years listed the surround speakers as parallelled with the rear doors and having caps on them, on this year/model it's not the same. The surround speakers are on their own channels, no caps, no continuity with rear doors, on their own - direct to amp
Oem amp 12v+ = red/yel - pin 4
Oem amp gnd = blk/white - pin 8
Overall system turned out good and sounded great, customer happy. Only hiccup was using GTO signal sense on the lc2i, so either use "audio" or a dedicated switched source for remote in.
Hope this helps
** previous
iamlegion
I have the bose performance series system and tapped in the sub channel, no ANC bypass and no issues. I think there’s a lot of misinformation online that the ANC on all models and amp combinations even uses the sub at all for ANC.
With the Lc2i you probably can compensate for using a door speaker but you’ll probably lose some Hz on the lower end.
remmy
Sorry to bring up a thread from the dead. May you elaborate a little more? Ive got a '26 Yukon XL AT4 with teh 10 speaker system. I see what looks like micophones in the headliner above driver and front passenger. Thats not ANC or is it for phone use? I gotta do something about this bass. For a $95k vehicle this is patheitc.
iamlegion
What do you want clarification on?
If you have a sub then you have a decent signal line to tap into.
Regardless if your mics are used for ANC (I don’t think they are in that system) my experience, in MY system was that the ANC system isn’t playing the noise out of the subwoofer at all - it’s the door and maybe dash speakers. Therefore if you aren’t tapping a speaker that’s playing the ANC signal back, you have no reason to try and figure out how to bypass that.
remmy
Thanks for that. I've been doing some research. I contacted GM and they said my truck doesn't have ANC. But I also reached out to PAC and they said the AP4-GM81 module will work thus eleiminating the Bose amp to its entirety and give me L/R/S outputs. On top of that, I saw JL is making OEM drop-in speakers that fit GM. Technically, you could have an entirely aftermarket system without cutting or drilling a single thing in the truck outside of running power wire. The PAC unit comes with a harness to utilize the OEM speaker wire harnesses. This is extremely attractive to me so I've decided to go this route and am starting to save up and acquire parts. Ill see where the simple onboard EQ of the PAC gets me before adding DSP.
Grocery list:
PAC AmpPRO AP4-GM81
Sony XM-8ES 8ch Amp
JL CF-690-RTG 2-way Components
JL C2-6650X Coax
JL Stealthbox
mudrunnerz
