Smoked corners and tails help...
BennyR72
Los Angeles, CA
Wondering what the best way to put a dark smoke on my corners and tails is on my 96 2DR Hoe. Don't want to put caps on and the only replacement ones i can seem to find online have a very light smoke to them. Looking to more or less black them out but keep function. Ideas or suggestions?
foreverfalcon40
I wanna tint my tails too but to match my paint...what do u guys suggest. I've seen some pretty ****** black on black tint jobs. Want that gloss look!
Oklahoma
Use a paint and clear coat mix. Cant get anymore glossy than that.
When I had my stocks
97yukon
baton rouge
ive done a few sets with vht...great stuff but be sure to wet sand the shit out of your lights before you apply first coat. if you want them black....3 coats is perfect...mine are almost completely black and light comes through them perfectly. if you want a real glossy finish...lightly wet sand between coats. heres what mine look like:
drowndindreams
Unknown
clean with carburator spray before. it'll get rid of any waxy dirt. then clean with any household spray. you'll get a nice glossy clean coat.
BennyR72
BennyR72
Los Angeles, CA
I've done and re-done it like 3 times now with VHT Night Shade and keep getting cracks in the paint after the 1st coat. Here's what I've done:
1st Attempt:
Cleaned with carb cleaner then washed with regular dish soap.
Dried and wet sanded with 1500
2nd Attempt:
Sanded with 320 to get the old coat off.
Washed with carb cleaner and dish soap
3rd Attempt:
Sanded with 320 again!
Washed with carb cleaner and soap again!
Dried and painted (no wet sand this time)
It got a little better after the 3rd try, but i'm still getting cracks on the bottom corners.
Anyone else had this problem/figured out a solution?
riviera rider
if you guys can do it you can ship me your lights and ill black them out with intercoat clear mixed with black base then with 3 coats of clear over them so you can wetsand and buff them anytime u want
50$ a set let me know only take me a day to do and then i can ship them out the day after painting them
did my tahoe both tails and 3rd brake light
i can either mask of the reverse or black it out like on mine
TheBigler
Mobile, Alabama
I need help. I bought a pair of taillights from a junk yard to tint out using VHT. I prepped them by cleaning them with a restoration kit then wet sanded them with 1500 grade paper and washed them off. I laid the first base coat and let it dry inside my garage but 15 minutes later when I came back the paint was all cracked and looked like ass. I sanded it down with a higher grade then repainted them. I did this two more times and its getting better progressively. Any advice as to what I’m doing wrong or how I can fix this faster???
riviera rider
whats happening is the paint is "lifting" its due to either the paint not wanting to stick to the plastic, or something on the plastic
ive heard many people say the same thing about using vht, which is why i offered to do everyones the right way with a transparent black coat and 3 coats of clear, no cracking, no fading, and u can even wetsand and buff them
Tankball
Yo man I am definitely interested in this. Could you make them more of a "smoke" color instead of all the way black? Like a dark grey or whatever. If you can send me a private message with your contact info and we can work something out.
Thanks man
95tahoe
B.C. Canada
any updates thebigler? im having the same problem. i think it may have to do with possibly to heavy of coats but im still barely putting any on. i wet sanded with 2000 followed by a clean with rubbing alcohal then vht.
nickyg1478
Oklahoma
I used VHT Niteshade and wetsanded it thoroughly beforehand. I put on around 8 or 9 coats to get it really dark and did not bother with a clear coat. Turned out great-looking.
bowtiefreak
No Quarter
Near Philly
I had some ugly old tails that were a gift so I did my best to paint them to match...I miss my stockers though.
Before:
After:
dizhai
